Results 1 to 10 of 3070
April 5th, 2011 08:13 PM #1
Sir magtatanong lang po, i'm planning to setup my car audio with 2 power amps, isa pong 4 channel for front and rear speakers and 2 channel bridgeable 760W x 1 (4Ohm brigded) for subwoofer (10" DVC * 2 Ohm 350W RMS or 1200W Max)
Sir ang tanong ko po ay yung magiging power supply ng dalawang amps? direct po ba ito from the battery or may iba pang power supply na kakailanganin? hindi po ba magkaroon ng concern sa power requirement ng dalawang amplifier, knowing that it will eat lots of power when it's ON. di ba magdidiskarga ang baterya sir? TIA po..for any feedback and suggestion.
April 6th, 2011 09:53 AM #2
4ga power cable po, direct from battery of at least 80amps fuse in line near the battery, of course that system draws a lot of current so when playing, always turn on your engine to stabilize your current, i also recommend additional of at least 2 farad capacitor near to the amp for additional support to your system and get the best performance of sound even in the long run. You will be needed also a 1 in 4 out distribution block for splitting the power wires easily.
personally, i'd think thrice, before buying that toyota brand new rack and pinion, to fix my 2003...
rack and pinion repair
