Results 1 to 14 of 14
    What's up everyone....Does anyone here have a Dual Alternator for their Sound System? Because i'm planning to run a....
    2 Alpine MRD1000 Mono Amp
    http://www.crutchfield.com/S-sJWoI8P...MRD-M1000.html
    1 Alpine MRV F540 100w x 4 4 channel Amp
    http://www.crutchfield.com/S-3Bwn62t...-MRV-F540.html
    1 Alpine MRV T320 100w x 2 2 channel Amp
    http://www.crutchfield.com/S-bOFG859...ab=other_items
    7 Band EQ or Crossover
    3 1 Farad Capacitors
    2 7.5 inch LCD Monitor
    Alpine iDA-X305S
    http://www.alpine-usa.com/product/view/ida-x305s
    with this toy's, i got to have the juice!
    what vehicle
    :-) im glad you reply hahaha i forgot to mention it. its a 99 honda civic VTi. thanks for your interest....i really appreciated.
    you can buy a high ampere alternator 200-300 amperes then replace the original alt with the high ampere alt.
    Quote Originally Posted by ARB View Post
    Actually it's my 2nd option to look for after market alternator with high amperes. since you mention it, do you know where i can get this compatible to my ride? or maybe a custom made for my ride. dual alternator or just 1 with high output it doesn't really matter to me as long as it feeds my system with right amount of juice :-)
    we installed a 200 ampere mechman alt on a civic vti by custom fabricating the bracket of the original alt. it powers 1 RF 1500BD, 1 RF 1000BD, and 1 RF punch 800.4. We can let the system play for hours without problems.
    Sep 2008
    would you know how much is your ampere load or requirements? thanks
    the required is 280 amperes based n the wattage
    this is what im talking about....where did you get this project done? my amplifiers are set all i need is the juice to power all my toy's. i have a
    2 ALPINE MRD 1000 1000x1
    1 ALPINE MRV F540 100x4
    1 ALPINE MRV T320 100x2
    where did you get the brackets fabricated? i want to go to the same place where you get this dual alternator. thanks for replying i really appreciated. i'm glad to hear from you....thanks again...
    Quote Originally Posted by bmacavanza View Post
    It takes about 16 amps of electrical power for every 100 watts of audio output. now if you crank up the volume then it pulls more. how much? that dpends how high you turn your volume. hope this helps....
    we installed the alt and the audio system for ur customer. but we are based in the visayas, but im pretty sure there are a lot of shps in manila that can do the same.
    Ouch! I Thought my problem solved....I Thought you're from around manila :-) but anyway...thanks for replying tho. really appreciated....Hopefully someone around in manila will jump on this thread. I'm really dying to have one for my ride :-( thanks again ARB...
    ARB, are you from Cebu? I have a friend there who's planning to install a high ampere alternator for his sound system. Maybe I can refer him to you.
    sir Bacolod City.
Dual Alternator for Massive Wattage
