Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Jan 2004
    Mga kaibigan...what can you say about these?
    http://www.woofersetc.com/product.as...4&1=317&3=1257
    mura ba yan for US$189.99??
    or
    http://www.woofersetc.com/product.as...4&1=317&3=1195
    at US$179.99
    or
    would you suggest dyan na ako sa Pinas bumili? Approx P10K yun, so ano options ko for a seps?
    Thanks for your help...
    DLS is a good brand too...7k and up for the 2-way reference series i think.
    Feb 2004
    masmura yan.... dito sa pinas, i think mga 15-16k sya...
    or try to check ebay. definitely alot of good stuffs there. kung mag ebay ka, try to find focals too
    Jan 2004
    guys, thanks for the info...by the way, where can I get DLS dyan sa atin?
    Jan 2004
    Cardo818, mura ba 165H - Focal 6.5" Polyflex Component at US$173.99??? Between the JL and this, which one is better?
    Im also considering DLS (as recommended by ssalon), sa pinas na ako bili, para wala na ako bitbitin pauwi...hmmmm, what do you think?
    Salamat po.
    Feb 2004
    UP series ng DLS maganda din...
    maestro, i really cant say eh... i havent heard yun specific models... K2 ng focals lang ang napapakinggan ko pa... and DLS iridiums
    Jan 2004
    Thanks Cardo818,i think i'll get the JL seps...by the way, might also get a matching subs with it...they are available in 2,4,8 ohms...which one should I get???
    Feb 2004
    depends sa amp mo siguro... its power rating at 2, or 4 ohms
    Jan 2004
    Thank you guys...
    Actually, nag-iisip pa ako if I will buy here sa US, hirap kasi mag-bitbit pauwi...if ever dyan ako sa Pinas bibili, what are my options for P15-20K (for seps, sub and amp lang)??? Kulang ba ito?
    Beginner lang po ako, appreciate your help guys!
    bitin yan pare. unless di ka brand conscious. kasi sa iniisip mo na brands for seps, slashed by half na agad yung 20k budget mo para don palang. shempre kung high-end yung seps mo, you'd have to get a powerful amp to juice up your seps to maximize its potential. that's discounting your sub and amp to power it pa.
    Jan 2004
    Thanks SSAloon. Sorry dami ko tanong, kasi zero knowledge lang ako...kaka-enganyo lang when I started reading these threads....
    Value for money, which set is worth buying? Actually, yun set1, medyo sakit na sa bulsa ko. Pero if mura talga sya, kakayanin...
    set1:
    -JL 10W3V2 D2 10" subs, US$130 (or should I get the 10WO?)
    -JL VR600CSi-6" ComponentSystem, US151.95
    set2:
    - INFINITY KAPPA 100.3DVC SUB WOOFER 1100W SUBWOOFER, US$65.77
    - INFINITY KAPPA 50.5CS 5.25" COMPONENT SPEAKERS, US$ 117.77
    Please feel free to give other suggestions.
    Yun AMP, dyan na ako bibili kasi mabigat eh.
    Thanks!!!
    Feb 2004
    if you are in the states, i suggest you get everything there, balikbayan box lang katapat nyan
    check out www.thezeb.com and www.ikesound.com and www.sounddomain.com
    palaging may sale dyan on separates, amps and subs.
    the money that you save will be well worth it.
    let's say budget mo is $400, lets see what we can come up with.
    at thezeb, CDT audio separates are going for $150
    sa sounddomain, xtant 3 channel amp (50W x 2 + 100W x 1 ) is going for $160
    at thezeb, a 12 rockford fosgate punch subwoofer is going for $80
    total is $390.
    if you take more time to surf the web, you will get better deals.
    andy
    Jan 2004
    Thanks! might just do that.
    Need your help again. Alin mas ok dito:
    1) AUDIOBAHN A6004T 4 CHANNEL AMPLIFIER NEW 04 600 WATT
    Class A/B MOSFET Power Amplifier
    2? Stable Stereo
    Requlated Power Supply
    Full MOSFET Circuitry
    Double Sided Circuit Board
    Air Induction Fan Cooled
    RCA (Low Level) & Speaker (Hi Level) Inputs
    RCA Outputs
    Variable Hi Pass Crossover : 50Hz to 750Hz
    Variable Low Pass Crossover : 50Hz to 120Hz
    Variable Subsonic Filter : 20Hz to 50Hz
    Signal To Noise Ratio : > 100dB
    18dB Bass Boost
    T.H.D. : 0.02%
    2/3/4/5/6 Channel Operation (Mixed Mono)
    Soft Start Circuitry
    25A x 2 Fuses
    Dimensions : 9-7/8"W x 1-7/8"H x 9-7/8"D
    White Cloth Handling Gloves
    Audiobahn Window Sticker
    Frequency Response : 10Hz - 40KHz (+/- 1dB)
    3-way Protection Circuitry: Thermal, Short Circuit and Overload; Cooling Fan
    Cobalt Blue Illumination
    High gloss Chrome Plated Finish
    Nickel Plated Block Terminals
    4? Stereo : 75W x 4
    2? Stereo : 150W x 4
    4? Mono : 300W x 2
    OR
    2) LIGHTNING AUDIO S4.600 4 CHANNEL NEW AMP HIGH POWER HOT
    All measurements * 14V unless otherwise specified
    Frequency Response (4-ohm IHF Load, 20 Hz to 20 kHz, 1 kHz Ref.: channel 1 & 2, +0.02 dB, -0.4 dB; channel 3 & 4, +0.3 dB, -0.7 dB
    L/R channel error (max deviation 20 Hz to 20 kHz: channel 1 & 2, 0.7 dB; channel 3 & 4, 0.2 dB
    Phase Response (4-ohm IHF Load, 20 Hz to 20 kHz, 1 kHz Ref.): channel 1 & 2, +14 degrees, -20 degrees; channel 3 & 4 +10 degrees, -23.4 degrees
    Signal-to-Noise Ratio (Below Rated Output, "A" weighted): channel 1 & 2 -94.8 dB; channel 3 & 4, -94.7 dB
    Distortion at Rated Output * 1 kHz: channel 1 & 2, 0.12% * 180 watts; channel 3 & 4, 0.11% * 450 watts
    Output Power (resistive) minimum output (20 Hz to 20 kHz * 1% THD+N, all channels driven into 4 ohms: 75 watts x 2 + 173 watts x2 * 14 volts; 62 watts x 2 + 143 watts x 2 * 12.8 volts; 39 watts x 2 + 92 watts x 2 * 10.5 volts
    Output Power (resistive) minimum output (20 Hz to 20 kHz * 1% THD+N, all channels driven into 2 ohms): 103 watts x 2 + 248 watts x 2 * 14 volts; 85 watts x 2 + 204 watts x 2 * 12.8 volts; 54 watts x 2 + 130 watts x 2 * 10.5 volts
    Output Power (4-ohm IHF Reactive Load * 60 Hz to 1% THD+N): 252 watts + 562 watts
    Crosstalk (Referenced to Rated Output, 20 Hz to 20 kHz): channel 1 & 2, -58.5dB; channel 3 & 4 -45.8 dB
    Damping Factor * 100 Hz, 2 ohms: channel 1 & 2, 63; channel 3 & 4, 81
    Voltage for Rated Output: channel 1 & 2, 144 mV to 4.5 volts; channel 3 & 4, 147 mV to 4 volts
    Idle Current Draw: 0.7 amps
    Current Draw * 1/3 Maximum Power: 57.6 amps * 253.6 watts
    Efficiency * 1/3 Maximum Power: 31%
    Power-Up Noise: 31.2 dB SPL
    Power-Down Noise: 44.2
    Both selling at US$149.99...mura ba yan?
    Feb 2004
    the subsonic filter on the audiobahn is a nice feature especially if you are going to bridge the rear channel and use it to drive a ported sub. i am saying this because with a moderate wattage for a sub, ported would be the most efficient
    a lot of people keep saying that audiobahn is all show and no go, i have no personal experience with either of the two amp nor any of their product line, so i can't really give an educated opinion
    andy
    Jan 2004
    thanks Andy.
    Nakita ko yun CDT audio sa thezeb...less 15% pa! lalabas sya at US$127 plus around $10 shipping... do you think its a good deal?? di kasi ako familiar dahil talgang wala akong alam sa audio....let me know your suggestion...
    thanks!!!
    Feb 2004
    although i haven't heard them in person, i know of very serious car audio competitors who sing praises for CDT, especially at that price. just take a look at their current lineup and the prices, they are very expensive. parang disposal price na yan kasi older model, but if i had the budget, i would go for them. ang ganda ng presyo na yan pare.
    andy
    Feb 2004
    nakakainggit naman kayo! hehehe try nyo rin mag ebay guys! I think masmarami pa mura dun... maganda kumuha ng wala dito sa pinas, para atleast pagdating mo dito - "wow! ganda! san mo nabili yan? wala yan dito ah" hehehe...
    Jan 2004
    tempting!!! ... sige, i'll sleep on it...
    Thanks to Andy, SSaloon and Cardo for all your professional help...by the way, I did purchase some items from ebay... Amp and subs so far... pero yun CDT, wala dun eh.
    Thanks again!
    Feb 2004
    what car will you be installing it in? i think those on sale are the 5.25 inch separates?
    andy
    Jan 2004
    I ordered it already!!!...will install in Paj Gen 2...Its a 6.5" seps... Actually, ang labo nga kasi mas mahal yun 5.25" keysa sa 6.5"... Bale, US$127 lang, from orig price of $299!....Thanks Andy!
VR600CSi - JL Audio 6" (or 5.25") VR Series Component
