Guys where do you usually good deals for audio stuffs like HU's, amps? So I'll just go there and buy na lang. I'm slowly buying stuffs for my SQ set up!
Shops suggestions in Raon and banawe are really appreciated.
intense, C3 sa banawe. better yet, shop around sa KAC, daming good deals yun and better pricing since you're buying direct sa seller unlike sa shops na may patong pa.
try mo rin sa jetcar bro. hanapin mo si jerry.. ok kausap un.. sabihin mo nirefer kita..
o kaya sa teamcar sa may kanto bago mag q.ave from retiro.. hanapin mo naman si kerwin.. he knows me din.. ok mga 2 yan.. subok ko na.. sa mga banawe part yan.. merun din mga magaling na installer like kela db audio.. si rocky din.. see their contact nos. sa KAC
Nasa G. Puyat St., comming from Raon nasa right side. Di ko alam mga katabi niyang stores. Ok dun, 1yr. warranty yung mga V12 amp, yung ibang shop mga 3 or 6mos. lang.
Zanch: The Fenton you inquired, is it a 2-channel or a 4-channel? A V12 705 will be good enough to power your Seps and 12" Sub, but don't expect too much. If you can source a second hand Fenton 4300 get it, I heard that it has "cleaner" signals compared to the 705 but I think this model has been phased out. You can also check the Fenton 41000, Its bigger than the 705 and has a lifetime warranty from Dai Ichi.
