Results 1 to 20 of 21
    good day everyone, just wondering ilan kailangan na rate ng alternator if im putting in HID(siguro 6000k), SPL sound system (2 amp na jbl then 12" subs, seps, and crossover)
    im plannig to put it sana pero takot ako baka hindi kayanin ng alternator ko. currently, i have a 1 amp sound setup and H4 narva super white 100/120 ata. kaya naman ng alternator ko but if i was to do the above metioned anong rating kailangan ko para hindi mabitin sa power.
    magkano kaya abutin ng higher rated na alternator?
    thanks sa magreply.
    Why 2 amps for 1 sub and seps?
    Personally I don't think you'd need to change alternator for that (depends on your car though). Mababa rin ang power rating ng standard HID's diyan compared sa super white na gamit mo ngayon.
    Kung takot kang madiskarga, it would be best to buy a secondary battery instead kaysa palit ng alternator.
    thanks for the input batang raon
    baka confusing pagpost ko... my current setup is 1 amp lang, so kaya ng alternator. ang plan ko is to upgrade my sound system to a 2 amp setup (SPL) + HID 6000k. takot lang ako na hindi kayanin ng alternator yung plan ko na setup... so kaya ng alternator basta may isa pang batt? thats good to know
    Mar 2005
    Planning on using 1 amp for your sub and 1 for your seps?
    Anyway, I don't think you would need another battery. I've seen setups with 3 amps on 1 battery. Also, most HID's are rated at 35w so it uses less power than ordinary headlights (usually at 60w). If there are signs na kulang ang charge (radio turns off when you turn headlights on, step on the brake etc) have your alternator checked with your suking electrician. Baka maluwag yung belt or kailangan na magpalit ng carbon brush. Pero kung di naman, mag capacitor ka na lang.
    I have a fairly decent setup wired 1 amp sa subs and another amp sa 2 sets of seps 75x4 lots of little things like neon and strobes sa trunk, upgrade halogen lamp, and decent two tone horn additional cabin lights (maplight)
    Upgrade lang ako sa battery and installed kinetik power cell as backup sa likod.. kayang kaya lahat ng load I tried cranking up my setup with all efects on di naman nag drop below 12V engine off after 20mins of playing, even the bass is thumping I observe the voltage stable naman...
    I saw one serious SPL setup sa Fortuner additional backup battery lang din ang nilalagay nila.
    should be ok...i have run 1000w amps on stock Toyota alternators before...
    May 2007
    Quote Originally Posted by archie123456789 View Post
    thanks sa magreply.
    Go ahead....load it up, walang problema diyan. But, if you go higher or add more AUDIO BLING BLING need to upgrade your Alt. should I say, 95 ampere.
    Jul 2006
    You can complete the package and go with an Optima Deep Cycle battery (yellow top) for all your electronic needs.
    Aug 2006
    Quote Originally Posted by v6dreamer View Post
    X2
    anong ride ba???
    Dec 2007
    Bro, depende sa rating ng audio setup mo na ilalagay dyan... as for the HID, it really doesn't take much current, kasi 35W lang yan, kahit 55W na HID, di pa din mararamdaman ng stock alternator mo yan...
    Kung JBL amps naman gamit mo, kung GTO series lang yan, they wont really eat up a lot of current... capacitor na lang ang idagdag mo. Or kung gusto mo din maka-sure pa, if you have currently, say, a 1SNF battery, go buy yourself a size bigger than it...
cars with big load of electronics
