Results 1 to 6 of 6
    Good PM mga paps,
    Mga paps pa tulong naman sa sound ng ride ko. 2 months palang kasi sa akin so mejo matagal tagal pa gastusin hehehe.
    ito yung current setup
    Pioneer Mosfet DEH P5450 (di nakaka basa ng MP3 kaya papalitan ko talaga ito)
    Alpine 3542 Bridgeable Power amp
    Pioneer TS-G1647 16cm Coaxial 2 way 150watt (rear)
    Yung 2 speaker sa front pioneer din nakita ko lang nung nagpaayos ako ng power mirror.
    Kapag ang volume ko nasa 12 or 13 na mejo parang di na maganda tunog. Gusto ko sana mag dagdag ng sound box sa trunk pero sana yung di masyado malaki para may space pa ako sa trunk..
    Suggestion naman dyan mga paps. Di ko naman balak magpakalabog ng sobrang lakas ehehehe.
    TIA
    Quote Originally Posted by Dead Guy Sligh View Post
    Good PM mga paps,
    Why not get an experienced shop to sort out the problems with your current sound system before spending more money on it? If you are near Cubao, the shop SUN-X located in Auto-Centro (behind Ali Mall) can help your car audio problems.
    That's what they all say at first.
    Jun 2008
    have your setup check first by good shops in banawe and tell them what you want to achieved. get quotations and decide which setup will satisfy your need.
    Good PM mga paps,
    TIA
    Hi..Hanggang saan yong maximum ng Volume mo? naka Dahil paglow volume ka palang tapos hindi na maganda ang tunog..pagnakakabit ba ang mga speakers mo sa amp hindi match ang GAIN settings mo o masyadong mataas ang Gain..Mangyayari magclip agad ang system mo..May mga device na pwidi mo gamtin sa pagmatch..Pero on the amps "manual" gusto nila Minimum muna ang Gain (Gain eg. 9 volts -200mV bare in mind ang 9volts ang Minimum sa Amp), Zero volume on the Hu..then play a song(CD you prefered) then do the HU first bring up the volume hanggang 3/4 then slowly bring up your Amps Gain until you hear a distortion/clip then slowly bring it down again hanggang mawala ang clipping/distortion..I hope this help but " If symptoms persist consult your doctor" LOL.. Good Luck!
    Good PM mga paps,
    TIA
    Hi..Hanggang saan yong maximum ng Volume mo? Dahil paglow volume ka palang tapos hindi na maganda ang tunog..pagnakakabit ba ang mga speakers mo sa amp hindi match ang GAIN settings mo o masyadong mataas ang Gain..Mangyayari magclip agad ang system mo..May mga device na pwidi mo gamtin sa pagmatch..Pero on the amps "manual" gusto nila Minimum muna ang Gain (Gain eg. 9 volts -200mV bare in mind ang 9volts ang Minimum sa Amp), Zero volume on the Hu..then play a song(CD you prefered) then do the HU first bring up the volume hanggang 3/4 then slowly bring up your Amps Gain until you hear a distortion/clip then slowly bring it down again hanggang mawala ang clipping/distortion..I hope this help but " If symptoms persist consult your doctor" LOL.. Good Luck!
    How many Alpine 3542 you have? this power all your speakers? how did you wire it?
    Buy decent HU - Thats where the source of music came from.
    Buy Decent seps - Thats where the source is reproduce.
    Add ka amp to drive your sub, use the Alpine amp to drive the seps
    Ditch your Pioneer speakers
    Have it installed by reputable installer
    BTW ano pala ride mo sir?
Need help (car audio upgrade)
