test
Page 65 of 81 FirstFirst ... 155561626364656667686975 ... LastLast
Results 1,281 to 1,300 of 1618
Thread: Avanza Periodic Maintenance Service (PMS)
  1. #1281
    Join Date
    Apr 2008
    Default Re: Avanza Periodic Maintenance Service (PMS)
    I had my PMS 40k, after my last PMS 33k naka fully synthetic kasi so my SA mentioned na ok lang na sa 40k na ang susunod na PMS.
    I just want to share eto po ang damage and the service done:
    40T KM Check up - Use Fully Synthetic oil 1275
    Toyota Brake Flud x2 310.36
    TGFS, SM 5W40 L - x3 1647.33
    Element S/A Oil Fltr - 357.02
    Plug Spark x4 - 491.28
    Gasket 25.25
    TWWF W765 85.91
    TSLC (2 Liters) 592.12
    TGMG (GL-4 80W-90) 675.45
    TGDG (GL-5 85W-90) 649.47
    GREASE (Lubricant) 8.93
    Brake Cleaner 199.37
    Sand Paper 18
    Package Wash 625
    ATF 317.86
    Miscel 60.26
    Oring small 31.25
    less discount labor -127.5
    less discount parts -483.42
    6758
    vat 811
    so mga around 7.5k
    naka 10% discount po, as suggested by my SA kasi frequent customer.
    Sa TYT Makati po ito at ang SA ay si Kuy Ogie De Vera (Recommended)
    madami po ako natutunan sa baback read ng mga posts ikinuwento ko sa SA bago ko pina service... salamat sa forum na to.
    Inspected valve clearance
    Inspected Cooling & heating system
    Replaced Engine Oil / Filter
    Inspected Engine Coolang
    Replaced Spark Plugs w/ 3-way catalytic converter
    Replaced Air Filter (pero mukhang di pinalitan kasi sabi ng SA good pa daw)
    Inspected fuel tank cap, fuel lines & conn
    Inspected Charcoal Canister
    Replaced Brake Flud
    Replaced Diff Gear Oil
    Inspected Transaxle/ xmission oil for MT
    Inspected, cleaned adjusted Brake Lining & Drums
    Inspected Brake Pads & Discs
    Inspected Brake Line Pipes & Hoses
    Inspected Steering Wheel Linkage & Gear Box
    Inspected Front & Rear Suspension
    Inspected Air conditioning
    Inspected Drive BElts
    Inspected Exhausg Pipes & Mountings
    Replaced Fuel Filter ( di naman pinalitan kasi sabi ko di naman kelangan)
    Inspected Choke System
    Inspected PCV Valves Ventilation Hoses & Connections
    Inspected Brake Pedal & Park Brakes
    Inspected Power Steering Fluid
    Inspected Weel Alignment
    Inspected Drive Shaft Boots
    Inspected Ball Joints & Dust Covers
    ITightened Bolts & Nuts
    Inspected Tire Pressure
    Inspected Lights, Horn, wipers & washers
    Road test
    Inspected Timing Belt ( at 80000km)
  2. #1282
    Join Date
    Jan 2011
    mga sirs...patanong po...papa-drain ko yun coolant ng avanza ko...di ko alam kung anong brand ginamit ng dating may-ari...aalamin ko lang kung ilang liters ng coolant (plus distlled water) ang kailangan ko pangpalit
    TIA
  3. #1283
    Join Date
    Quote Originally Posted by maguire View Post
    TIA
    50-50 as always ang ratio,
    prestone, na "anti boil" and "anti rust", pang Asian climate, available sa ACE...
    sorry i don't have info for how much the capacity needs for our vanzy, my rough estimate is 1 3/4 gallon
  4. #1284
    Join Date
    Jan 2011
    Mga sir, magtatanong lang po, pag open ang window ng driver at passenger side sa unahan (half open) nakakarining po ako ng parang kumakalampag na salamin sa magkabilang window habang tumatakbo po ako...hindi ko alam kung saan naggagaling yun...hinahawakan ko naman yun magkabilang window fixed naman sya di naman maluwag...nakakairita tuloy habang tumatakbo hindi tuloy smooth...ang suspect ko baka may loose na bolt sa sidings pero takot akong buksan baka di ko maibalik ng maayos...meron na po bang naka experience ng ganito sa inyo? help naman po...by the way my vanzy is 1.5G AT (36,000+++ mileage)
  5. #1285
    Join Date
    Jan 2011
    share ko lang
    mileage 15,283 (acquired 2nd hand avz g manual)
    at shell gas station (a.bonifacio)
    Change oil (shell helix 10W-40) P894
    top1 (oil additive) P180
    engine flush P149
    oil filter (bosch) P225
    coolant P341
    labor P200
    tip P100
    total = P2089
    spark plugs (denso - bought from toyota casa) 550.23
    wheel alignment and camber (left front) at servitek = P550
  6. #1286
    Join Date
    Oct 2009
    Hello there... ask ko lang po kung magkano ang standard ng 30K PMS? Meron ba kayong itemized details? Fully Synthetic Oil or Mineral Oil lang?
  7. #1287
    Join Date
    Jan 2011
    ask ko lng po kung ma void po ba ang warranty kung na miss nya ung 15k and 20k PMS???? 1k, 10k lng sya nag PMS... magpapa PMS po ksi ngaun kasi ma reach na nya ung 25k,,,,,,, how much po kaya magastos ko???? thanks
  8. #1288
    Join Date
    Sep 2005
    yes as per Toyota.. void na warranty nyan pag na miss nyo yung PMS nyo lalo na kung 10K ang na miss.. masyado nang matagal yan..
  9. #1289
    Join Date
    may labor bang 550 lang? 1T+ na yung labor alam ko eh..
    My 25k km pms labor is 550, TYT CDO
  10. #1290
    Join Date
    Apr 2010
    Quote Originally Posted by xda2jojo View Post
    itatry ko din sila dun sir jojo.. pagka 30k pms ko...
  11. #1291
    Join Date
    Jan 2011
    thanks po,,,,
    pero sir qwerty,,, last pms nya po ay 10k,,
  12. #1292
    Join Date
    Sep 2005
    I meant more than 10T kms na ang na miss nya sa PMS..
    Quote Originally Posted by ericksmolina View Post
    thanks po,,,,
  13. #1293
    Join Date
    Apr 2008
    Gasket 25.25
    TWWF W765 85.91
    Sand Paper 18
    Package Wash 625
    ATF 317.86
    Miscel 60.26
    Oring small 31.25
    TWWF W765 85.91
    Alin po kaya dito ang engine oil? at ilang liters po kaya. sa labas sana ako papa-PMS tapos bibili na lang ako ng orig TYT oil.
    Plan ko po kasi sa petron na lang.
  14. #1294
    Join Date
    Jan 2004
    ito po yung engine oil. 3 liter po sa J and 3.2 liters of oil pag G.
  15. #1295
    Join Date
    Apr 2008
    Quote Originally Posted by ching View Post
    transmission oil pala po. alin po kaya.
  16. #1296
    Join Date
    This one, 5W40, Synthetic - Engine Oil
    GL-4 80W-90, Synthetic Gear Lube for Rear Axle(Differential)
    GL-5 85W-90, 'matic Gear Oil
  17. #1297
    Join Date
    Quote Originally Posted by ngarcia View Post
    May na scanned ako from OM sir
    http://www.avanzaclub.ph/forum/index...sg1952#msg1952
    baka makatulong sayo
  18. #1298
    Join Date
    Apr 2008
    salamat po sir.
  19. #1299
    Join Date
    Jan 2011
    Toyota pasig allows outside orig oil. Pasig even allows imported OEM toyota oil filter. Innova oil filter is 90915-yzzd1(denso) or 90915-yzzg1(US). I am not sure about Avanza's filter but I found out Innova and Fortuner oil filters are the same. Tacoma 2.7L Engine is the same as the 2.7L Fortuner engine. Tacoma uses 90915-yzzd1 or 90915-yzzg1. Anyway, brought my own 6quarts of mobil 1 10w-30(5quart jug and 1 quart bottle) and IKH20 iridium plug from US for my 20K PMS INNOVA. Labor 1148, oil filter 426, drain plug gasket 28, misc 112 and sandpaper 25. Total P1740. I suggest you buy 5quart jug in walmart for $24 or a box for 6 quart in Costco wholesale for $34.
  20. #1300
    Join Date
    Mar 2011
    so para hindi po ma-void, kailangan sundin yung pms schedule? ask ko na rin po, dapat sa casa lang magpa-pms so that the warranty wont void? thanks po
Posting Permissions
  • You may not post replies
  • You may not edit your posts
