Page 1 of 2 12 LastLast
Results 1 to 10 of 248
  1. #1
    Join Date
    Apr 2006
    Talking Re: Avanza Headlight Upgrade
    Sir,
    Stock replacement ba yan ? extra wirings needed or Relays to be aded?
    FYI na din. for those that has plan for HID upgrades, make sure that the grounding terminal is grounded properly and if it has stock terminal ground connectors have it replace by a gold plated terminal connector otherwise you may encounter intermitent HID lighting (this was my problem for 2weeks sometimes the it wont light up either left or right ) i had my terminal grounding connector replace using a spare gold plated AMP terminal connector
  2. #2
    Join Date
    Default Re: Avanza Headlight Upgrade
    stock wattage at 55/60W. no need for wiring and socket upgrades. tipid
  3. #3
    Join Date
    Aug 2005
    Quote Originally Posted by t3kk3n View Post
    Sir,
    Yup, Plug and play lang.
    *t3kk3n, sample wall shot ng HID mo. TIA.
  4. #4
    Join Date
    Aug 2007
    For those who want to upgrade their stock Avanza headlights to Philips X-treme Power H4 (very much recommended for illumination improvement of your front beam over the stock 55/60W H4 bulb), you can avail the 20% x-mas discount from Autosport Megamall. I just got mine last Friday for only P1,160 bucks per pair (before P1,450 without the 20% x-mas sale discount). I already used my new Philips X-treme Power H4 during my early morning trip bound to North Luzon last saturday and I was a bit surprised with the big improvement considering that it is the same power consumption of our stock bulb. Long beam, and it really illuminates the dark asphalt finished hiways like the NLEX and SCTEX. Superb Product!
  5. #5
    Join Date
    very nice info, regarding the camera. basta naka automatic mode, the camera will always balance the lighting so that the image will always look "normal". so dapat naka manual yan with same iso settings before and after. thanks!
  6. #6
    Join Date
    Aug 2005
    Quote Originally Posted by Islaw*Palitaw View Post
    Hi Islaw, sorry hindi ko masagot ang SMS mo. Nagka problem kasi ako sa phone ko.
    Thanks for the heads up sa auto sport. I got mine there at 1450 a pair. . Nice timing
  7. #7
    Join Date
    May 2008
    just had my headlight replacement to philips xtreme ok naman. sa perfedt dirdle din ako nagpapalit kagaya ni qwerty 1300 kuha ko.
  8. #8
    Join Date
    Oct 2008
    Quote Originally Posted by badbutchoy View Post
    san po yng perferct circle? wla pa bo malapit sa marikina area?
  9. #9
    Join Date
    Feb 2009
    Hello mga Sir,
    Nasaan banda yung Autosport sa Megamall?
  10. #10
    Join Date
    Aug 2005
    Quote Originally Posted by jocas0922 View Post
    Hello mga Sir,
    Bldg A yata iyon, ground floor or 2nd flr malapit sa dulo (opposite ng bldg B) sa may power books (?).
Posting Permissions
  • You may not post replies
  • You may not edit your posts
