Results 11 to 20 of 248
Thread: Avanza Headlight Upgrade
December 14th, 2008, 06:47 PM #11Tsikot Member Rank 3
- Apr 2007
- 1,076
Re: Avanza Headlight Upgrade
nagpalit na rin ako ng headlight..dun sa sinabi ni qwertz..
anlaki nga ng difference dun sa stock..mas malakas pa nga ang lowbeam nito kesa dun sa stock na naka hi beam..
dati kailangan ko pa test on and off kung nakasindi ba talaga ilaw ko...
last saturday night with my kids..naka lowbeam na nga ako..nag signal pa kasalubong na mag baba daw ako ng ilaw..akala siguro naka hi beam ako...
December 15th, 2008, 11:43 AM #12
Ang pattern ng buga sa low beam natin ay "_/_/". kung natapat siya sa ilalim ng "/" ay silaw nga siya.
December 18th, 2008, 07:28 PM #13Verified Tsikot Member
- Oct 2008
- 380
December 19th, 2008, 01:30 PM #14
December 19th, 2008, 01:58 PM #15
December 19th, 2008, 11:02 PM #16
December 20th, 2008, 08:21 PM #17
Sir,
Stock replacement ba yan ? extra wirings needed or Relays to be aded?
FYI na din. for those that has plan for HID upgrades, make sure that the grounding terminal is grounded properly and if it has stock terminal ground connectors have it replace by a gold plated terminal connector otherwise you may encounter intermitent HID lighting (this was my problem for 2weeks sometimes the it wont light up either left or right ) i had my terminal grounding connector replace using a spare gold plated AMP terminal connector
December 20th, 2008, 09:33 PM #18
stock wattage at 55/60W. no need for wiring and socket upgrades. tipid
December 21st, 2008, 03:22 AM #19
December 22nd, 2008, 12:32 AM #20
For those who want to upgrade their stock Avanza headlights to Philips X-treme Power H4 (very much recommended for illumination improvement of your front beam over the stock 55/60W H4 bulb), you can avail the 20% x-mas discount from Autosport Megamall. I just got mine last Friday for only P1,160 bucks per pair (before P1,450 without the 20% x-mas sale discount). I already used my new Philips X-treme Power H4 during my early morning trip bound to North Luzon last saturday and I was a bit surprised with the big improvement considering that it is the same power consumption of our stock bulb. Long beam, and it really illuminates the dark asphalt finished hiways like the NLEX and SCTEX. Superb Product!
Xiaomi E-Car
