Results 61 to 70 of 294
May 23rd, 2008, 10:18 AM #61
Re: Avanza DIY (Insulating Firewall & Ceiling + bluelight)
Sir Marfin galing mo talaga...walang pinagkaiba, sana magawa ko din to sa G ko, pahingi ng lakas ng loob.
May 23rd, 2008, 10:21 AM #62
Wow, ayos, ah. Kung hindi tinandaan yung dating BEFORE pic at hindi makikitang nabawasan yung insulation dun sa isang picture, mahirap i-determine kung alin ang BEFORE at alin ang AFTER. Very nicely done! Congrats!
Now you just have to install pull handles on the 3rd row, man. Patronize your own ba. Hehehehehehehe....Last edited by woohoo; May 23rd, 2008 at 10:23 AM.
May 23rd, 2008, 10:27 AM #63
Galing Galing!
Now ang kulang na lang ay makita ang effect sa aircon.
May 23rd, 2008, 01:05 PM #64
- Mar 2007
- 143
Galing naman. Ang Innova po ba ay wala ring insulator? Will check pa ito this coming week end. Benchmark ko gawa ni sir marfin.....
May 23rd, 2008, 03:32 PM #65
I bet wala lahat ganyang insulation ang mga Toyota. Good luck, tedd! Balitaan mo kami sa results mo, ha.
- MAD
May 23rd, 2008, 03:33 PM #66
* marfin...
Thanks for sharing your great DIY procedures.... Keep them coming!
May 24th, 2008, 03:14 PM #67
Re: Avanza DIY (Insulating Door)
Probably my vanzy would be completely wrap with this insulation material at the end.... ha..ha..
Insulating Door or rather door sound proofing?
Purpose:
- Improve the speakers sound
- Sound deadening
- comfort ??
Open up the doortrim of avanza J. this is what we can see. (there is like plastic material used to cover the door.
I decide to remove this and replace it with the thin insulating material. (5mm one sided, cost: 48pesos/M)
Next step is making the mold, just simply use our doortrim to make this mold.
This is how I install it.
Note:
After installed the right door part, i decide to test my speaker.., result: more bass sound compare to the left door(uninsulated)
ENJOY YOUR DIY...
May 24th, 2008, 04:19 PM #68
Bro Marfin very nice DIY for the insulation. We will look forward for more DIY's from you on our Avanza. Keep it up!!
May 26th, 2008, 10:10 AM #69
May 26th, 2008, 10:28 AM #70
Sa wakas, naikabit ko na rin ang foam insulation sa Avanza ko. Bad trip nga lang dahil makulimlim ngayon, hindi ko masusubok.
Anyway, good news: Parehong-pareho lang ang Avanza J at Avanza G sa ceiling!
May dalawang window panels nga lang na kailangan pang baklasin. At bago mabaklas yung panels, kailangan pang tanggalin ang seat belts.
Kaya, Mod Shadow, kung may balak kang kabitan din ng insulation yung Avanza mo, I suggest na unahin mo yun bago pa dumating yung door trims mo, para less work.
Note: Nakita ko sa Ace Hardware ang pinaka-effective na paraan ng pagkabit ng insulation sa BUBONG NG BAHAY. Kapag nasa ibabaw ng purlins ang insulation, dapat hindi flat ang pagkabit, dapat mayroong air space between the insulation and the G.I. sheet (yero) ng bubong. Bale naka curve pababa yung foam in between purlins. Kung sa ilalim ng purlins yung foam, no problem. Mas matipid pala kung sa ilalim ikinabit. Bad trip, hindi ko na mababago yung sa bahay, naka-flat siya sa yero. Di pala alam ng mga nagkabit yung tamang paraan.
So, having found out about this way of installing, hindi ko na ginaya yung pagkabit ni Marfin na naka-flush siya sa bubong. Ni-shoot ko na lang paloob ang foam para may air space kahit konti. Less work pa. Hehehehe.
Another difference is, I approached the front part from the driver's side. Less work again, dahil walang pull handle na kailangang tanggalin. O di ba?
Hindi ko na ipo-post yung pics na kagaya nung kay Marfin, dahil parehong-pareho naman ang makikita ninyo. So yung mga nuances ng G-variant na lang, saka yung mga "enhancements" na ginawa ko.
To be continued...Last edited by woohoo; May 26th, 2008 at 10:36 AM. Reason: (ngek, kasama pala ang smilies sa images...)
How? What to upload in lieu of the COC No?
LTO car registration and late registration fees
