Results 121 to 130 of 294
July 9th, 2008, 02:48 PM #121
Re: Avanza DIY (Insulating Firewall & Ceiling + bluelight)
[quote=meledson;1100586]K3-VE ang makina ng mga 1.3J avanza natin, para maging K3-VET, mayroon turbo na bolt-on option.
Nice concept, 1.3 engine with turbo will add lots of kilometer per liter. worry ko lang yung piston and piston ring kasi di sya built for turbo baka mag-melt.
And one thing for sure it's expensive; first you'll need a bolt on turbo kit, optional yung blow off valve; then there are lots of gauges and sensors to run a turbo engine in a satisfaction like turbo boost gauges, oil pressure gauges with sensors. An optional oil cooler is required.
Sa turbo kit palang lots of (Ninoy's) na ang kailangan.......HEHEHEHEHE
July 9th, 2008, 03:51 PM #122
[quote=junlatorre;1100480]Bro Marfin
Ano ba ang goodies sa avanza sa indonesia? Kasi ngayon si vanzy ko naka chrome handle, central lock, gas cap cover, step board( actually ayoko nito kasi bigla di bumagay nun nag 15s ako e kaso wala ako magawa si esmi nagpakabit nung wala ako).
Ang next step project ko (3m tint all around), free flow muff (pero ayoko maingay, gusto ko un turbo style na big can), free flow intake (kung me makuha ako K & N na drop in sa orig housing) or para nun sa iyo o ke querty ba un na naka funnel. headers di ko masyado priority pero kung meron reasonable ok din. Ok un grille mo na me TRD. Wala ba programmable na chip?? para ma alter ko lang ang fuel map pampatipid hehe at konti torque. Hopefully makauwi ako dis december kung payagan ng mga bosing.
Hi tension wires meron din ba? pero ang stock ok din maayos naman ang mga modelo.
Sir, WERTY po.
Wala pang K & N na drop in sa orig housing, all you could do modify a air intake funnel then attach a K & N filter. Headers po is ok, dapat lang buong exhaust system ang upgrade to prevent slowing down the engine.
Wala din high tension wires yung k3 engine ng avanza direct po siya sa computer box, kung mag programmable chip ka, advise upgrade ka ng computer box yung pang stage one racing, it will add an additional 20-30 Hp. Considering gas consumption You can add an fuel managemant system that will control the flow of gasoline from the tank to the intake system.
About sa grille, pwede po kayo umorder saken, pero optional po yung TRD na emblem. Abanggan mo yung body kits bka late this july matapos ipost me yung finish product when done.....
July 10th, 2008, 02:11 AM #123Verified Tsikot Member
- Jun 2006
- 254
Bro Werty
makano ang grill?? taga laguna kami sa may southwoods exit. Kahit ke esmi ko pakuha kung malapit kasi wala ako ngaon dito.
Sa mga balak magturbo, basta stay below 9psi wala ka dapat katakot sa reliability di mo kailangan mag alter ng fuel at timing map. Basta complete kasa safeguards, wastegate, intercooler or water/methanol injection at di super bigat ng paa. Pero remember boost is not always the best basta kahit low boost ka pero well prepped ang setup mo, smooth ang pipes, at least 2.5 inch exhaust, malakas na ang 7psi for street driven vehicles. matipid ang turbo pag cruising speeds pero sa stop and go di masyado.
PAg balak mo mag big boost yan na ang mods, forged pistons, upgrade ng injectors, at fuel pump, remap ka ng chip, bigger brakes at tibay ng dibdib.
Un pare ko si Dondi Montecillo, yan ang nakalakihan namin ang set up and tuning sa turbo cars, kaht Carb type or EFI. Me nagawa kami na corolla xe blow thru lang na set up 8 psi ang lakas.
Pero mag alter ka ng turbo mawala ang warranty mo sa vanzy.
Jun
July 10th, 2008, 02:16 AM #124Verified Tsikot Member
- Jun 2006
- 254
Bro Werty
Actually di ko pa masyado na usyoso ang vanzy ko kasi 2 weeks lang akokung umuwi, napasin ko nga sa pics na direct fire ang set up natin me individual coils bawat spark plug. Me available na ba na chip para sa vanzy? Baka me alam kayo surplus na box ng vanzy try ko pa break ang code hehee para ma remap.
Jun
July 10th, 2008, 02:56 AM #125
Bro Jun & Bro Werty,
nag enjoy ako dun sa discussion nyo ah......medyo masyadong technical sa pandinig ko pero medyo din nakaka-relate naman he he he....naisip ko tuloy anu na naman ba ito UPGRADE na naman nun ngang kay WERTY ng makita ko last saturday yung makina nya at naka convert na yung air filter na katulad din nung kay woohoo at ini-explain nya kung bakit..... sabi ko .....aba mukhang oks ito ah.... kasi nga medyo bitin din ako sa power ng 1.3 natin parang kulang/bitin sa response ang makina......di bale Bro Jun pag umuwi ka at gumawa ka ng upgrade sa vanzy mo kahit mini EB lang tayong mga taga laguna he he he...oooops..pero kung gustong sumama nung iba sa Eb welcome naman
July 10th, 2008, 06:13 AM #126Verified Tsikot Member
- Jun 2006
- 254
Bro Jaspi
Taga san ka sa san pedro?
Ang power ng 1.3 swabe lang pero pag nag kick na ang vvti ok na din at sarap ng tunog ng honk ng intake kahit stock lalo na siguro ang mga naka funnel na air filter.
Sa mga balak mag DIY ng turbo pwede din madami surplus na turbo na pang nissan mga 3.5 to 4k mo makuha, ang plumbing abutin ka mga 10 to 15 k, tapos silicone hoses mga 3k, intercooler nasa 2.5 k ang surplus, full exhaust na 2.5 inches pati muff nasa mga 6k depende sa muffler shop na gagawa, water injector pwede na winshield washer tapos pressure switch lang, me nabibili na preset ang activation nya kung 5psi, etc. boost gauge mga 1.5k, ang BOV (blow off valve para di sumabog ang cold pipe at throttle body) nasa mga 4.5 to 6k ang branded, machine shop para sa pag weld ng oil drain ng turbo sa oil pan, 1.5k, various hoses, mga 4k. Para safe mga 40 to 50k araaayy madami nga ninoy aquino sabi ni Werty. TUning, hehe ilang case ba tayo ng beer??
Pero sa mahal ng gaso, ang mods mo un dapat un makakatipd at di masyado masakit sa bulsa.
Ayos
Jun
July 10th, 2008, 06:34 AM #127Verified Tsikot Member
- Jun 2006
- 254
Bro Werty
Ang makakamelt ng pistons pag ang boost mo e sumobra sa fuel delivery mo na mag lean out ang makina tapos mag detonate ng husto, un makarinig ka ng parang pumipitik na sound under boost un na un detonation na. Kaya angat ang paa hahaa.
Sa mga modelo usually mag fuel cut off pag me engine management ka na stand alone para buhay ang makina mo.
Jun
July 11th, 2008, 02:51 PM #128
[quote=junlatorre;1100947]Bro Werty
sir Jun
2 piece grille po yan ( txt lng po if intrested)* werty 09178628853
2.5t yun baba
1.5t yun taas
July 11th, 2008, 09:32 PM #129
July 12th, 2008, 01:20 AM #130
* Jaspi11
Sir, Eto yung pix ng manibela.
eto pa isa, medyo may faded portion pero orig.
How? What to upload in lieu of the COC No?
LTO car registration and late registration fees
