test
Results 1 to 20 of 33
Thread: Amateur painting DIY for the Avanza.
  1. #1
    Join Date
    Aug 2005
    Default Amateur painting DIY for the Avanza.
    For me this is a simple pero major project.
    After removing the battery terminals (positive first), battery clamp and the battery it self. this is what I have found:
    After removing the battery tray:
    After using a paint brush to remove some of the dust:
    Yes it its corroded. this is casued by the battery acid falling on the tray and then going into the metal part.
  2. #2
    Join Date
    Aug 2005
    Default Re: Amateur painting DIY for the Avanza.
    After some sanding:
    Right after using the turco rust converter:
    while waiting for the rust converter to do the job. the battery tray after some cleaning:
    Turco rust converter dried:
  3. #3
    Join Date
    Aug 2005
    painting using hi-temp paint:
    after 3 layers:
    battery tray installed.
    The "head" of the bolts and washer are also rusted. Planning to replace them later with a stainless hex bolt. this is the bolt in the tray. Unfortunately it is a sunday so I was not able to buy more bolts and stainless washer.
    Battery, battery clamps and battery terminal clamps returned.
    Lessons learned:
    1. for best results, all original paint must be removed
    2. turco dries best over night. i waited for 3 hours only
    3. socket wrench with rachet is the best tool.
    4. I should have use flat black not glossy black for the hi-temp spray paint.
  4. #4
    Join Date
    Uuuuyyyy type ko din itong DIY na ito....sad thing di pa kaya ng powers ko na magbaklas ng car batt...
    sana project natin ito sa future EB....
  5. #5
    Join Date
    Oct 2007
    pres mali kulay dapat blue din, hehehe
  6. #6
    Join Date
    Aug 2005
    Quote Originally Posted by shadow3616931 View Post
    Ang tamang kulay ay parang dark green. black lang kasi available ang hi-temp paint ng bumili ako sa ace. Anyway, tago naman. ang purpose ko ay para hindi lumala ang kalawang.
    I think, lahat ng local avanza has the same color sa engine bay.
  7. #7
    Join Date
    Aug 2007
    Lessons learned:
    Another option is to use a clear quick drying enamel spray paint over the original black color to make it glossy. I use the same spray paint with my mud guard which makes it more resistant to sticky and stuborn mud...hehehehe
Posting Permissions
  • You may not post replies
  • You may not edit your posts
