Results 1 to 10 of 30
- May 2018
- 39
December 28th, 2018 06:45 PM #1I have tried several touch up paints online pero medyo malayo pa rin with the color. Is there a shop that sells paint mix or touch paint that is exact code with your car color?
Will just use it as a touch up paint, since recently I noticed dami na small marks/scratches na macover sana with touch up paint.
December 29th, 2018 12:25 AM #2
Perhaps you can try asking your dealer. If you are in good terms with the warranty officer, it should be easy.
For slight scratches, I tried this one and somehow effective for me.
You can also check this out:
Automotive Touch Up Paint from PaintScratch - Order Pro Grade Paint - PaintScratch.com
December 29th, 2018 12:48 AM #3
Mr. Do It Colorlab. They can compu-mix based on your car's paint code & pack in aerosol cans.
- Jun 2005
- 3,774
December 29th, 2018 10:54 AM #4
December 29th, 2018 11:09 AM #5
December 29th, 2018 11:53 AM #6
I bought mine in ebay. It’s a plastic canister with a foam brush & a roller ball. The other canister is a clear coat. Cost P1,000 with free shipping from Korea. I just provided the paint code. Color exact.
- May 2018
- 39
December 29th, 2018 04:40 PM #7
December 29th, 2018 04:59 PM #8
- May 2018
- 39
January 20th, 2019 03:23 PM #9
- Mar 2010
- 2,275
January 21st, 2019 09:08 AM #10In my case Ertiga, there is a color code stamp on the passenger side, then tangalin ninyo yung gas cover then dalhin ninyo sa suking expert na pintor at siya na ang bahala.
Result was perfect.
Couldn't have explained it better myself. This was the point I was making. They (either manually or...
SC (temporarily) stops NCAP
