Results 1 to 18 of 18
    Jun 2010
    Currently looking for a cheap but quality buffing machine. Napapagod na kasi ako imano-mano wax yung van namin. Any suggestion? Max budget around 5k-ish. But better kung may 4k below na mapapakinabangan ng pang-matagalan. And please kindly enlightened me about this machine. Thanks in advance.
    Dec 2004
    I saw the cheapest one at Shopwise, in the P 1700 range - orbital buffer/polisher.
    I have an identical one which Walmart sells for ~$26 including tax so it would end up around P 1250.
    http://www.walmart.com/ip/10-Random-...uffer/39881400
    It comes with a sponge applicator bonnet and a microfiber polishing bonnet. Decent enough to give the car a good shine. I like the sponge bonnet since it spreads out the product evenly. I also find it quite efficient because the head has a non-absorbent backing which keeps the product on the sponge - I use just half a sachet of product (around 15ml) for a mid-size sedan. The microfiber bonnet is also ok, though I find I need to pat it off every now and then to remove the accumulated product and keep the fibers loose.
    Am I satisfied with it? Yes. I end up using it every six weeks to reapply wax. It's cheap but I do not see the need right now to get a more upscale one. My detailing routine takes a shorter time with the polisher than without. This even if I still need to do some areas by hand since the 10-inch head cannot access them.
    Is it hard to use? Put it this way - I get equally tired using the polisher as detailing manually alone. My back doesn't hurt as much using the polisher though since I do not bend over as long, but my arms get more tired because of the machine's vibration. Not sure if this is inherent to orbital buffers or if a pricier one vibrates less. But then again, I'm probably much older than you
    My neighbor uses a non dual action polisher on his van. It seems to work. He seems to like it. He uses collinite for boats lol.
    I would use a liquid wax if no polisher is used.
    Collinite is a wonderful product and it aint cheap... It performs very very good.
    Up ko lang... Im also looking for a polisher. Thanks
    Sent from my SM-A510Y using Tapatalk
    Jul 2015
    Quote Originally Posted by joey_ed27 View Post
    PM mo bro si Ginnova, he has a wide range orbital polishers. Yung mga nabibili sa hardware stores like B&D, they will get the job done kng mag aaply k lng ng wax, pero kung mag correct ka ng paint, better check ginnova's selection.
    Salamat bro
    May 2012
    Matatangal ba ng polisher yung white na namuo sa hood galing sa hamog?
    Feb 2016
    Maganda ba yung sa lazada na nasa P1,200 ang price? Pang wax lang po.
    Sent from my Starmobile PLAY Click using Tsikot Forums mobile app
    Feb 2017
    black and decker 3k
    Sep 2021
    maybe you can consider the rongpeng air sander,the quality is good.
    5" Air Sander Self Vacuuming RP7335S
    May 2016
    Im also looking for DA polisher. San makakabili. Nacheck ko na ACE, blade, wilcon. Mostly rotary lg.
    Aug 2012
    Quote Originally Posted by krau55 View Post
    DA Polisher, you can inquire here:
    D3 Technologies | Facebook
    Sent from my D5833 using Tapatalk
    Jul 2011
    Quote Originally Posted by red_one View Post
    Sir any feedback s rockwell shop pro series na benta ni d3 technologies
    Aug 2012
    Quote Originally Posted by chelle011 View Post
    I personally use the same model. Good build. Gets the job done easily.
    Oct 2013
    I got my polsiher from car care ph on facebook. shinemate yung brand. very good quality naman, and the best prices ive found in the country
    Oct 2013
    inquire here for DA polishers
    Car Care PH | Facebook
    Jul 2013
    Quote Originally Posted by bloojet View Post
    DELETED[/url]
    He is looking for a buffing machine and you reply by promoting something else.
The best cheap Polisher buffing machine
