Hi mga Sirs,
What are the best brands of Heavy Duty Air Compressors that you can recommend. It will be used mostly for Car Painting using a Spray Gun.
Thanks in advance...
Hi mga Sirs,
May mga bagong labas na oil less type compressor. May mga compressor na pang paint talaga like power craft compressors. Also need nyo yung 50L or more kasi yung maliit mahihirapan mag maintain ng air pressure kasi sa painting tuloy tuloy ang buga.
^After gamitin, remove bottom drain plug to drain water para tumagal ang tank. Make sure to install air filter to remove air on the output.
If may budget screw type air compressor. Atlas Copco, hitachi, IR, etc
Sent from my SM-G965F using Tapatalk
