Page 1 of 6 12345 ... LastLast
Results 1 to 20 of 101
    Feb 2017
    Saan mo nabili at anong brand yan? Maganda ba
    Ito lang mga available online, handyman, ace, blade, true value and concorde.
    mothers na may kasmang detailing spray at itong blue na clay bar available online
    Yes. I use Mother's. I bought it in Amazon but I saw it at True Value.
    Apr 2012
    Yes, Mothers clay kit din gamit ko. but it's quite expensive at saka madaling maubos yung instant detailer/lubricant na kasama. kung gusto mo makatipid, bili ka ng blue clay bar online then ang gamitin mong lubricant spray ay yung Optimum no Rinse diluted sa water, o kaya water with car shampoo, o kaya plain water pwede naman. be generous lang sa pag-spray ng lubricant and ensure na well lubricated yung paint surface while claying to minimize swirls o marring. check mo kay sir Ginnova ng Reflections car care baka meron siya.
    Jan 2013
    Mother's din gamit ko. Bought sa shop nila sa Kamias.
    Sent from my ONEPLUS A3000 using Tapatalk
    The same ba ito sa blue clay bar from lazada? I'm contemplating on getting one but doubtful ako sa result.
    Sent from my SM-A720F using Tapatalk
    thanks for reminding... adding clayblock to the shopping cart [emoji16]
    Oct 2003
    You can use clay bar (mothers or meguiars). Mothers has their speed clay. I personally use a clay block from chemical guys or clay disc from sonax or nanoskin's clay sponge.
    For lubrication, you can use their dedicated clay lubricant or QD, waterless washes from optimum or ultima works well too. If lahat wala yan, you can use car shampoo as your lubricant for claying. Then rinse na lang after that.
    Mar 2017
    I use Mother's SpeedClay 2.0, lubed with ONR. Works well for light-medium contamination. I also use a fallout remover (Sonax brand) to ensure a nice clean surface prior to polishing. I do this every 6 months.
    Apr 2012
    Quote Originally Posted by alrorskyz View Post
    not sure but i think halos magka-kapareho naman yan. yun nga play dough pwede rin din daw yata pang clay lols! sekreto diyan is yung lubricant, use generous amount of lube while claying. kaya yung mother's kit, matagal ng ubos yung instant detailer na kasama, hindi pa nagagamit ng buo yung isang clay bar.
    Mar 2004
    Using sponge bar ...
    Dec 2017
    I'm not sure if this is a clay bar as it doesn't feel like a clay. I'm about to try it today.
    Jan 2018
    Yes, please update us on how it goes. I saw that before when I was looking for a traditional claybar.
    I saw something similar last night on YT. I think you use it to scrub the car in lieu of the wash mitt after applying the shampoo.
    no lube... no bueno
    no lube... no bueno
    The shampoo acts as the lube. You use it like a washmitt as the shampoo is on the car.
    Mar 2017
    That's what I use. Lube liberally. Rinse it well if you drop it and it should be good to go again. Store in a cool place else the tacky rubber will melt.
    some shampoos dont have "lube" properties that clay lube products have, except rinse less wash products like ONR or UWW
    some shampoos dont have "lube" properties that clay lube products have.
    Well the video did have a caption on a particular shampoo the shop used during the "claying". Not sure if that claybar works but just saying there is such a thing.
    Mar 2017
    Shampoo is fine since the Speed Clay is not as abrasive as regular clay bars, and is not meant for heavy contamination.
    I would suggest using the Speed Clay _after_ the wash (after rinsing, before drying), not during the "shampooing" stage to minimize any contaminants which could be dragged across the paint.
    FWIW I've been using this product for more than a year now (tested with detail spray, spray wax, ONR, shampoo), with no apparent marring on a black car.
    Oct 2003
    I think most important thing here is that, ONLY clay the vehicle when you feel that it needs it.
    Thats why if you have the budget, you can do chemical decontamination first (carpro iron x/gyeon iron/ nanoskin iron remover) and carpro tar x/ gyeon tar) to name a few products. These will dissolve and rinse away most contaminants unseen from the naked eye. AND then do mechanical decontamination (claying) if needed.
May gumagamit paba ng Clay bar?
