Results 1 to 10 of 10
    Jul 2017
    Hi mga Sirs,
    What are the best brands of Heavy Duty Air Compressors that you can recommend. It will be used mostly for Car Painting using a Spray Gun.
    Thanks in advance...
    Jun 2005
    Vespa is the common brand
    Sent from my MI MAX 2 using Tapatalk
    Quote Originally Posted by sirkosero View Post
    we have such vespa. over 20 years old.
    but we use it for compressed air cleaning and tire inflation.
    na-sira na dulo ng hose and electric cord (easy fixes), but the tank, electric motor and compressor are still original ok.
    magkano abutin pag complete set na bro for personal DIY use
    parang gusto ko mag aral mag paint ng auto eh ^_^
    Jun 2005
    Ready ka 15k more or less for compressor, water separator and paint gun
    hmm .. halos ka presyo na ng washover, pero pwede na
    pwede siguro gawin sideline ^_^
    Meron kami nito. I bought it in 2009 at raon pa.
    Hanggang ngayon buhay pa din. [emoji4]. Nagkaroon lang leak iyong kaha. Pina weld lang ng mekaniko namin tapos ayuz na uli. [emoji106]
    Jan 2008
    May mga bagong labas na oil less type compressor. May mga compressor na pang paint talaga like power craft compressors. Also need nyo yung 50L or more kasi yung maliit mahihirapan mag maintain ng air pressure kasi sa painting tuloy tuloy ang buga.
    ^After gamitin, remove bottom drain plug to drain water para tumagal ang tank. Make sure to install air filter to remove air on the output.
    Feb 2009
    If may budget screw type air compressor. Atlas Copco, hitachi, IR, etc
    Sent from my SM-G965F using Tapatalk
Heavy Duty Air Compressors for Spray Gun
