Results 1 to 8 of 8
- Dec 2008
- 4
January 18th, 2011 12:46 AM #1Is it possible? For the deep scratches, dings, dents? Pwede ba pukpok instead na masilyahan? Para purong lata pa din yung body ng auto. Kung posible, saang shop ang rekomendado nyo? Yung MAGALING, METIKULOSO at QUALITY talaga gumawa. Parang original paint quality pa rin. Thank you.
- Nov 2010
- 28
January 18th, 2011 12:21 PM #2Well as far as I know, if dents lang and the paint is still intact, then PDR or Paintless Dent Repair is all that you need. If Deep Scratches, yun tipong nabakbak na yun pintura and kita na yun metal, then kailngan na masilyahan bago pinturahan para pumantay yun paint. I think it depends on the scratch and dent if kailangan ng masilya.
San ba location nyo Sir? Kung sa south ka irecommend ko Roadstar Alabang sa Alabang Motortown for PDR, for body repair (and PDR too) sa RAR Auto Repair Center sa Bayanan, Muntinlupa
Hope it helps
- Jan 2011
- 3
January 19th, 2011 05:54 PM #3
- Dec 2008
- 4
January 20th, 2011 12:05 AM #4Thank you for your reply. Generally ok pa yung paint. Kaya lang may mga spots kasi na kailangan na i-repaint talaga dahil sa mga dents na may deep scratches din. However, nakakahinayang ipa-repaint yung buong car dahil lang dun sa ilan-ilan na problem areas, original pa kasi. Advisable ba yung spot painting? Magpapantay kaya sya sa original paint? Possible ba din yung purely pukpok lang lahat instead of using filler before repainting? As in hindi talaga gagamit ng masilya sa lata. Kaya ba ng latero yun? Mandaluyong area pala ko sir. Thanks!
Tsikot Member Rank 2
- Jan 2008
- 4,726
January 20th, 2011 12:15 AM #5hindi mag papantay yan kahit anong galing ng pintor kasi faded na yung paint mo compared sa bago.. so ang gagawin dyan eh pinturahan yung buong panel pero ganun pa din medyo malayo pa din ang kulay sa orig na lumang paint..
may contact dati ang tatay ko na gumagawa ng dent or yung mga lubog sa kaha gawa ng bangga.. magaling yung gumagawa kasi halos hindi na kailangan ng masilya yung kaha.. hindi nya pinukpok kaya hindi gasgas yung paint at bakal.. hinimas lang using his tools medyo mahirap at matagal pero sulit
- Jan 2010
- 126
January 21st, 2011 10:01 AM #6dapat po dyan ay spot repair lang para mag blend ang bagong paint sa original o lumang paint, sa panel repair lalo kang mag kakaproblema dahil di match sa dalawang katabing panel , nahihirapan ang mga pintor sa spot repair dahil wala sila noong tinatawag na COLOR BLENDING ADDITIVE is specifically made for spot repair and makes spray mist softer, thus smoothing the blending, para po si mahalata ang dulo o dugtungang ng kulay at kaya po ang maraming pintor ay mapipilitan buong panel na ang pinipinturahan para makaiwas sa ganitong problema at syiempre kailangan magaling ang pintor para makagawa ng di halata na repair
- Nov 2010
- 28
January 24th, 2011 10:14 AM #7*shmuck316 Nagpa PDR lang ako this month sa Alabang Motortown for multiple roof dents, medyo kalakihan pero kayang kaya ayusin ng nag PDR sakin for only 1500 (Less than 2 hours).
About sa spot repair, I guess it depends on the painter. Had a spot repair done on my car before * Great Works Auto here in Muntinlupa. Very deep scratch, kita na yun metal but after the repair parang di nagasgasan yun car ko, no need for hilamos. I have some light scratches on some other part of my car mostly on the fenders and buffing did the job. Yes possible hindi na gumamit ng masilya kung kaya naman "pukpok" or some other way like they use in PDR (Paintless Dent Repair).
Hope this helps!
- Dec 2008
- 4
it seems this company is slowly dying.... only service for Metro Manila will now be in Alabang only...
Volkswagen Philippines launches 5 new competitive...
