When I bought my second-hand car, meron mga nakadikit na wood trimmings dun sa may dash. Medyo nagsasawa na ako sa itsura, paano ba tinatanggal yun? Masisira ba yung dash kung tatanggalin yun? Thanks
heat it up first with a hair dryer and peel off the faux trim off the vinyl. You'll be left be adhesives on they vinyl surfaces, you can then remove those using a lot of adhesive remover.
puwede ba yang adhesive remover sa rugby because someone used rugby on my dashboard. what brand would you recommend and saan available? thanks:?:
