Results 1 to 18 of 18
    Jan 2013
    Ok lang ba mag pa hilamos during rainy season dito satin?
    Yung shop kasi na natanong ko may oven daw sila pero i havent seen their so called oven so im not use if its as capable as the ovens in US na kahit anong season ok lang mag parepaint. This is my first time kasi na mag pa hilamos nang auto.
    Thanks
    Sent from my GT-I9505 using Tapatalk 2
    Mar 2005
    Pag nag canvass ka ng paint shop sir pwede mo naman i request makita yung oven nila... Meron ako mga nakita shop na oven ovenan lang closed room lang na may mga halogen lights na pang pa init while meron ako shop na nakita na professional paint booth talaga yung may vaccum sa flooring para mahigop pababa yung mga alikabok prior to painting at gas yung gamit para pang heat sa loob ng oven.. So kahit tag ulan ok lang
    Jan 2013
    Quote Originally Posted by jmpet626 View Post
    Yun nga iniisip ko sir eh mura lang kasi quote sakin para sa hilamos kaya i doubt na pro oven yun kanila. Eh baka mamya hindi mag cure nang maayos yung paint kasi tag ulan.
    Apr 2012
    ano po ba ibig sabihin kapag sinabing hilamos?
    - total re-painting ba yan at papatungan ng manipis na pintura yung dati?
    - re-application ng clear coat?
    - full exterior detailing (prep > compounding > polishing/finishing > lsp)?
    TIA
    TIA
    Hilamos = Sand down then they apply new topcoat of paint and clear coat.
    Jan 2013
    TIA
    Hilamos sir is repaint na hindi strip to metal.
    Apr 2012
    Quote Originally Posted by man524 View Post
    thanks, now i know what "hilamos" means sa car paint palagi ko kasi naririnig yung salitang "hilamos" lang yan parang bago na ulit.
    i think hilamos is applicable lang kapag sobrang degraded na ang condition ng paint, yung tipong kupas na due to oxidation at maraming gasgas na malalalim. so kelangan na talaga lihain then i-compound.
    goodluck sa pa-hilamos mo sir man524...
    Jan 2013
    I have decided na ipasok na for hilamos sa sunday ko dalhin.
    Hopefully tama ang decision ko....
    Jan 2013
    Mukang umaayon ang panahon! :D
    Sep 2010
    where did you have it done and how much? how long did it take?
    Jul 2011
    Usually it is not good idea na magpahilamos kapag rainy season,
    iba padin ang finish ng paint pag ang oven mo is the natural heat of the Philippine summer.
    pero kung enclosed area naman with proper ventilation and cheaper ang singil, pwede na.
    kaya lang naman yung iba summer nagpapa-repaint, mas madali magpatuyo,
    mas madali magpatong ng another coat pag mainit ang temp and
    mas sigurado kang walang moisture between the metal and sa ibubugang primer/paint.
    *TS
    after ng ilang araw pagkatapos ng repaint,
    pag medyo maaraw, ibabad mo nalang sa labas para mas mabilis matuyo.
    and aside sa regular car wash, never do anything sa paint for atleast a month (detailing)
    hindi pa tuyo yan ng husto sa loob kaya better not do anything rough sa paint for the meantime.
    Jan 2013
    Hindi na ako naka reply. Actually it turned out pretty well naman. It was given enough time to cure then buffed, ayos ganda nang kinalabasan wetlook! lol. Ill post a pic soon.
    Btw the car is now with its new owner.
    Oct 2011
    Sir, San po kayo nagpahilamos and how much inabot? Thanks!
    Jan 2013
    Jan 2013
    Jan 2013
    Nov 2007
    Ganda ng result ah!
    Name ng shop and location sir?
    How much and duration ng hilamos?
    Jun 2011
    nagpa semi hilamos din ako TOP COAT ONLY (car show clear coat).... parang kulang kasi sa kintab, MAYBE because of its color may pagka light blue (ata yun)
    it turned out ok din naman... sa mga cheap CAR PAINTING SHOP ko lang pinagawa pero trusted ko kasi yung pintor... ( natulungan namin---- na torture dati kasi yun ng mga pulis pinapaamin sa crimen hindi naman nya ginawa)
    i'll try to post some pics...
Hilamos/repaint sa tag ulan
