what are some tips regarding this? is it worth trying or should i just pass? i happened to borrow a bottle from a friend. should i use a pre-wax cleaner or step one first? or can this be just used over wax? what are some tips on applying this (how much should be used and what cloth should be used)? thanks! hehe
Durashine is quite an old sealant... it acts just like any other sealant in terms of sheeting ability and application... It should NOT be applied over a wax since it needs to be applied directly to the paint... It's a dust magnet and doesn't feel slick at all... It's not a bad sealant but it's no better than low end sealants like Simoniz and Formula 2000.
so should i just skip it? in case i want to try it lang, parang for the meantime, i should clean the paint first? then apply durashine then wax over it right? may curing time pa ba to? thanks!
