Results 1 to 3 of 3
- Nov 2006
- 20
November 8th, 2006 02:05 AM #1mga sir, baka may marerefer kayo saken na nagbebenta ng 2nd hand lowering spring. sentra series2 oto ko. gusto ko sana 2 inch drop. putol lang kase ang saken ngayon. bale 2 ikot ang putol sa harap at likod.
nasa magkano ba ang brand new at 2nd hand na lowering spring para saken?
baka may marecomend din kayong shop na nagkakabit.
salamat mga sir.
November 8th, 2006 05:44 AM #2
Triplicate thread!
http://tsikot.yehey.com/forums/showthread.php?t=32504
http://tsikot.yehey.com/forums/showthread.php?t=32503
http://tsikot.yehey.com/forums/showthread.php?t=32505
Pakidelete na lang po.
Thanks.
November 8th, 2006 04:01 PM #3
Forget the 2" drop, the Sentra doesn't have enough front suspension travel for such a radical drop, and if you do drop that far on lowering springs, say good bye to your bushings within a few months.
Go for a 1 - 1.5" drop with lowering springs and find a good set of shocks, too, too stiff lowering springs will wear out the stock shocks (making the car handle like a floppy AUV) after a while.
high idle RPM at engine start
