Page 1 of 3 123 LastLast
Results 1 to 20 of 122
    Tsikot Waterless Car Wash Video Demo
    http://www.facebook.com/album.php?ai...9958917&ref=mf
    Before and After Pictures
    WHY WE’RE HERE?
    • Water crisis is getting worse every year
    • Water reservoirs running low
    • Lack of water supply in several communities
    • El Niņo is here to stay
    WHO WE SERVE?
    • You live in a flat or a condo that doesn't allow you to use a hose or bucket of water to clean your car.
    • You own a showroom that sells new or second hand car and don’t want to wet your floor.
    • You need to go out and your car is a bit dirty but don’t want to waste money and water to go to car wash.
    WE’RE A LITTLE BIT DIFFERENT AREN’T WE?
    NO WATER. JUST SPRAY-WIPE-BUFF!
    TSIKOT WATERLESS Carwash Solutions is not a car wash service, as you know it because there’s no water required in cleaning your car. This green innovation product will clean and polish your vehicle’s bodywork, glass and wheels without water. It contains premium soaps, surfactants, lubricating agents, and coco-based wax with polymer formula in cosmetic grade.
    With just “spray-wipe-buff” you’ll get a clean and shiny car. But it doesn’t only do the carwash; it also takes care of our environment.
    To Use:
    Step 1. PRE-CLEAN
    Gently wipe over the bodywork with a feather duster to remove dust, loose dirt and contaminants.
    Step 2: SPRAY
    Apply TSIKOT WATERLESS Carwash with an even mist, one section at a time, and allow a few seconds to penetrate.
    Step 3: WIPE & BUFF
    Use a microfiber towel to wipe off dirt and fresh contaminants. Then switch to a clean, folded, dry microfiber towel. Buff dry to a brilliant shine.
    PRODUCT LINES:
    TSIKOT WATERLESS CARWASH + POLISH
    WATERLESS CARWASH 380 mL is ideal for personal and commercial use. If you live in a flat and cannot use a hose or if you operate a car showroom and have no desire to move a car or wet your showroom floor...we have the solution! just “spray-wipe-buff”. It contains premium soaps, surfactants, lubricating agents, and coco-based wax with polymer formula in cosmetic grade. It’s safe for your skin, on car paints and to our environment.
    STEPS:
    1. Gently wipe over the bodywork with a feather duster to remove dust, loose dirt and contaminants.
    2. Apply TSIKOT WATERLESS Carwash with an even mist one section at a time and allow a few seconds to penetrate.
    3. Use the microfiber towel to wipe off dirt and fresh contaminants. Then switch to a clean, folded, dry microfiber towel. Buff dry to a brilliant shine.
    *Repeat steps 2 & 3 until vehicle is clean.
    380 mL=10-15 carwashes = save BUCKETS of water
    ALSO GOOD FOR MOTORCYCLES & BICYCLES.
    TSIKOT WATERLESS GLASS CLEANER
    WATERLESS GLASS CLEANER is the fastest way to clean your winshield.No need to bring buckets of water and other cleaning materials...just “spray-wipe-buff”. You won’t find harmful ingredients such as solvents and Volatile Organic Compounds (VOCs) in this glass cleaner, making it safe to use on treated windows and even glasses – helping to conserve the environment.
    STEPS
    1. Gently wipe over the windshield with a feather duster to remove dust, loose dirt and contaminants.
    2. Apply TSIKOT WATERLESS Glass Cleaner with an even mist one section at a time and allow a few seconds to penetrate.
    *Repeat steps 2 & 3 until glass is clean.
    380 mL=10-25 GLASS PANEL/CAR=save BUCKETS of water
    ALSO GOOD FOR glass, mirrors, plexiglass, tinted windows, light fixtures, crome and acrylic.
    TSIKOT WATERLESS TIRE + ENGINE CLEANER
    WATERLESS TIRE CLEANER is the quickest way to clean your tires and your engine too. No water needed...just “spray-wipe-buff”. This is an advance degreaser designed to remove common soil and oil deposits on your engine, under chassis, tires and your hub fender. It can be applied using a brush and cloth rug. Tough on dirt, but gentle on the environment.
    STEPS
    1. Apply TSIKOT WATERLESS Tire Cleaner, wet thoroughly and allow a few seconds to penetrate.
    2. Gently brush or wipe off dirt and fresh contaminants. Just clean one section at a time.
    3. Switch to a clean, folded, dry cloth then buff dry.
    *Repeat steps 1, 2 & 3 until tire is clean.
    380 mL=10-25 CLEAN TIRES=save BUCKETS of water
    NOW AVAILABLE at TSIKOT SHOP Taguig *P750 per set. Free product demonstration everyday between 9 to 5pm except tuesdays
    P395 waterless car wash
    P295 glass cleaner
    P295 tire cleaner and engine degreaser
    Feb 2010
    ayus po eto....... anyone tried using the waterless car wash......???
    pa comment po dun sa mga naka try na.....
    Quote Originally Posted by PSI View Post
    ill post a video demo soon much better pasyal ka dito sa shop sir... palinisan ko kotse mo
    wash and wax na ito... much cheaper sa traditional carwash and wax.
    im already using this for more than 2 months now bago kami nagdecide to market it. madami na gumagamit ng waterless carwash lalo na sa western countries.
    although pag sobrang maputik na... di na kakayanin... tubig na talaga katapat nuon.. but if you are always on the go like tadtad na alikabok, ipot ng ibon, watermarks, madali maglinis using Tsikot Waterless.
    yung manager ng st peter sa tabi ng tsikot shop, ito na pinapagamit sa driver nya habang walang ginagawa... before kasi naglalabas pa ng timba ng tubig to clean the car, ngayon spray na lang
    Apr 2010
    price list pls.
    Quote Originally Posted by nervenllarena View Post
    price list pls.
    P295 glass cleaner
    P750 1 set PROMO price
    Mar 2005
    Ilang gamitan yung waterless wash sir?
    Mar 2004
    Quote Originally Posted by jedi View Post
    sir kaya nito ang watermarks sa body at windshield?
    Quote Originally Posted by dbhollanda View Post
    yes sir, yung hindi kaya linisin ng water and shampoo na water/rain marks... natatanggal
    RE: Waterless wash, does it contain (mild or not) abrasives sir jedi?
    Feb 2009
    Close na tsikot taguig. Where na meron nito?
    Sent from my iPhone4 using Tapatalk
    Jul 2012
    Msy nakita ako v-kool paco nung waterless car wash and wax. Baka meron din hyundai paong tamo or ford bgc.
    Sent from my SGH-I777 using Tapatalk 2
    Jul 2011
    pwede kaya na after mag carwash pahiiran ulit ng car shampoo ung buong car then leave it to dry. para pag umulan ung dumi e madaling matangal. anong brand ng car shampoo kaya ang hindi makakasira ng paint pag naiwan
    Quote Originally Posted by Manilablock View Post
    but in the meantime that the it doesn't rain, the car attains that "tarred and feathered or sanded" look. heh heh.
    ang gawa ko, kapag nag-uumpisa na ang ulan, ay binubudburan ko si car ng tide..
    bolante!
    Sep 2010
    i've been using meg's ultimate wash and wax anywhere
    pag di ganong makapal yung alikabok.
    pag putik - car wash talaga punta ko.
    pag me time ako na nagwawax.
    Mar 2007
    I used Mantis waterless cleaner spray from Ace Hardware. Roughly 600 PHP.
    However, I don't apply this on a completely dry car. I sprayed my ride with water first, on a thought that the dirt will be washed off. Wiped off the water with mircofibre or chamois. Then sprayed Mantis, wiped and buff.
    So far, so good. The liquid has a fruity smell, I could almost drink it.
    Feb 2005
    Quote Originally Posted by xwangbu View Post
    Saan nabibili to at magkano? Has anyone seen the Pinnacle version, yung Liquid Crystal Waterless Auto Wash with Carnauba?
    May 2010
    Quote Originally Posted by LoBudget View Post
    Bought mine at True Value Shangrila, around 1.5k
    sir have you heard of glass coating? new tech from japan pwede po ako mag demokung gusto niyo 09258802406
    Feb 2005
    Quote Originally Posted by rayj012502 View Post
    Kung pwede lang pa clear screen protect ang buong auto like sa screen ng cellphone. Para protect na sa scratch and shiny look pa 👍😆
    Aug 2012
    Quote Originally Posted by strayWOLF View Post
    Kung pwede lang pa clear screen protect ang buong auto like sa screen ng cellphone. Para protect na sa scratch and shiny look pa ����
    Pwede naman. Use 3M Car Wrapping Film or AutoFoil Car Wrap.
Spray-Wipe-Buff Waterless Car Wash
