Results 1 to 9 of 9
    Nov 2006
    Kabadtrip un kapitbahay namin. Pag-uwi ko galing somewhere, may nakita akong specks of white paint sa right side ng altis namin! Ayun pala, may ginagawang something yung kapitbahay namin! Malamang e tumalsik un pintura because of their carelessness.
    My question is pano tanggalin un mga specks na un? Is there any way aside from kutkot using a used credit card or fingernails?
    Ang badtrip is bagong bago pa un altis namin. Wala pa ngang 2 linggo. Color black pa kaya kitang kita un specks. Any help would be appreciated.
    Sir IMO you can use a mild abrasive polish for that like Megs ScratchX, baka sakaling makuha pa.. Don't use rubbing compound lalo na't bago pa oto baka maging dull ang paint.. Or, better consult a professional detailer shop and let them diagnose it for you
    Wag niyo po kutkutin , magkaka-gasgas lang yan..
    Nov 2006
    thanks chikselog. Dalhin ko nalng to sa big berts and let's see kung ano marecommend nila.
    Jan 2009
    you can use a buffing machine. but better yet get some professional help. it's possible you might damage your top coat and even the base coat.
    Aug 2009
    *carchayser: dont and i say DONT!! use credit card and fingernails, it will just cause micro scratches or dull the paint, you could try to look for a hard enough clay to do the job, certain types of clay especially the heavy duty ones are capable of removing paint overspray and paint spots, and worse case is like what chickselog said, you might have to use a polish and a MF to remove it, ScratchX can surely remove it, but it can also surely remove some clear coat as well, in any case unless you have the clay and polish already, better have the professionals look at it, buying OTC clay would be too soft to do the job, and polishes don't come in small sizes so it might be more economical to have the pro's do it, also make sure your neighbor is done with whatever they are doing.
    Pero depende sa laki nung "specks" siguro. Gaano ba kalaki yung mga specks?
    Carchayser.....nangyari rin sa akin yan noon. Yung Mazda6 ko naman, na-anggi-an ng paint, spray naman ang ginamit nila. Naka park yung tsikot ko, malayo sa pader, pero mahangin, kaya yung pagi-spray paint nila sa pader, umabot sa tsikot ko. Ang daming tiny specks na color dirty white ang kulay, very visible sa kulay ng Mazda ko na Ebony black. Ginawa ko, pina-wax ko lang, sabay pa detail na rin.
    Solb ang problema.........
    Nov 2006
    Quote Originally Posted by madkatz View Post
    thanks madkatz! Actually bumili na nga lang ako ng car cover in case mangyari uli sa future.
    maliit lang nmn ang specks. pag gabi di mo mahahalata, sa umaga naman, unless titignan mo mabuti, di mo rn mapapansin pero once napansin mo na, you can't get your eyes off it hahaha. Ayoko pa sanang padetail since bago palang un koche, wala pang 2 weeks. I'll just check with big berts kung anong magagawa nila
Specks of white paint
