Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Sep 2008
    guys tanong ko lang kasi yung isang car namin madami na masyadong stickers sa windshield.gusto ko sanang tanggalin yung mga luma na like yung village stickers nung 2k5 pa or mga lumang LTO stickers para hindi sya crowded tingnan.napansin ko kasi mahirap sya tanggalin and parang tumigas na.
    Sep 2005
    use soapy water and a fresh Gilette blade to remove.
    Quote Originally Posted by interruptedz View Post
    I normally use a new razor blade set at a angle to get under the sticker. This usually leaves the least amount of gunk on the windshield. It also helps to pre-warm the windshield (to soften the glue).
    Oct 2011
    Gillete Blade + Alcohol should do the trick.
    Quote Originally Posted by russpogi View Post
    I prefer Admiral blade...
    yup, basahan lagyan mo konting mainit na tubig, tapos ilagay/babad mo dun sa ibabaw ng sticker, tanggal agad yan
    Jul 2006
    I'd forego with the razor blade and use a plastic spatula or same tool, and liberal amounts of heat from a heat gun. The razor blade can scratch the glass if incorrectly angled.
    Apr 2005
    If the stickers been there for quite a long time sometimes you can't avoid leaving adhesive residue behind. I use "Goo Gone" solvent bought from True Value. Just apply the solvent on a rag and you can wipe away the adhesive residue.
    Oct 2011
    OT:
    may nakikita akong presidential seal sticker sa windshield. saan ba pwede makakuha nun?
    OT:
    OT : sa malacanang.....
    para di OT, i use an adhesive remover.... kung talagang luma na yung sticker.
    otherwise, madali lang tungkabin yan ng cutter + water....
    Dec 2010
    basahan na may hot water babd mo lng dun hangng lumambot tangal yan
    never ako gumamit ng metal sa wondshield, lambot kaya ng automotive glass madaling ma-scratch. wd40 and plastic spatula. pag walang plastic yung organic. kuko.
    Apr 2005
    the best dito na pangtanggal, gas. tried it myself and walang kahirap hirap. try mo din
    ginawa ko 'to dati nung high school freshman ako. akala ko kung ingatan ko lang pag gamit ng phillips type screw driver at tubig as lubricant hindi magagasgas ang windshield. oh, how wrong was i
    basahan nga na babad sa hot water the best. tyagaan mo lang ng kuko kung naluto na sa araw ng kay tagal tagal
    Aug 2012
    OT:
    get friendly with PSG at checkpoints, they'll even offer you a car pass.
    Jun 2009
    I have a special tool in removing old LTO stickers and tints, made in Canada. I understand that this is not available locally and even accessories and service shops don't have this one. No need to use water, gas, chemicals whatsoever in removing old stickers, decals. So easy and convenient to use.
    Mar 2012
    Quote Originally Posted by nickriingen View Post
    would you like to share it then?
    Apr 2008
    OT:
    si PNoy nagbebenta sa malacanang
    seriously, saw them sold by guards at The Mansion in Baguio for PhP150.00 (three years ago i think)
    pinaka mahirap tanggalin na sticker para sakin is yung sa apple, parang naka laminate na sa windshield eh pero natanggal naman ng rubie na blade
    Basahan dipped in hot water din ginagamit ko.
How to take out Old stickers in the Windshield
