For ONR, post ko lang:
Here’s how it works:
Add 1 ounce of No Rinse Wash & Shine to 2 gallons of water to make an excellent no rinse car wash. Soak a microfiber towel in the solution and wash your vehicle with the wet towel. Dry each section with another microfiber towel. There’s no need to rinse! The lubricants and substantive polymers in the formula will protect your vehicle from abrasion as it safely cleans all vehicle surfaces. The polymers encapsulate dirt and cause it to drop to the bottom of the bucket. No Rinse Wash & Shine actually cleans the wash water as it cleans your vehicle! And it leaves your vehicle super slick, like it was just waxed!
Add 1 ounce to wash water made with your regular car wash. No Rinse Wash & Shine’s advanced polymers and lubricants offer more surface protection and slickness than ordinary car soap alone. It acts as a water softener and conditioner to improve the quality of the water that touches your vehicle to provide the ultimate safe wash.
Add 2 ounces of No Rinse Wash & Shine to a gallon of water to make a super-slick clay bar lubricant. Wet the surface of your vehicle to provide a slippery protective layer beneath Opti-clay. After you’ve clayed each section, simply wipe it dry. This solution is as effective as any clay lubricant you can buy!
Add 8 ounces of No Rinse Wash & Shine to a gallon of water to make an excellent quick detailer. Fill up a spray bottle with this mixture and use it to clean and shine your vehicle, just as you would use a traditional detailer. The proprietary polymers bond to the paint surface to protect it from abrasion and micro-marring as you clean. The incredible formula leaves your vehicle extremely slick and glossy, like you just applied wax!
Sent from my MI NOTE LTE using
Tsikot Forums mobile app
