Results 1 to 8 of 8
    Napansin ko na medyo may konting rust sa gitna ng disk rotors ng oto ko (mostly dun sa open space sa gitna mismo ng disk). Is it safe to use Turco Rust Converter to remove the rust formation or baka naman nakakapag pahina ito ng metal?
    actually you can, but you'll be better off scraping the rust off then primer and paint it if you don't like the way it looks. The rust wont really harm your metal since that's bare steel anyway... As for Turco, you can use it, it takes A LOT of coats to cover it right though... and dont let it touch the paint...
    thnx for the advice theveed
    Apr 2003
    Ask ko lang, may nabibili pa ba nito? Thanks.
    May 2005
    Quote Originally Posted by isketi
    try nyo po sa mga suking hardware or mga paintshop
    May 2005
    nagdoble ...soweee
    AFAIK yes, pero mas madami ako nakikita na Turbo na brand.
    Apr 2003
    Thanks peeps. Nakabili ako sa ACE Hardware. Meron din akong nakitang ibang brand, Pye Rust Converter, pero mas mahal.
