Results 1 to 9 of 9
    I'm just wondering what's the difference between these two and ano yung mas recommended gamitin.
    TIA
    Carnuba is supposed to be a harder wax (compared to regular car waxes) which is supposed to give your paint better protection against the elements.
    But carnuba is also more expensive. Up to you, either way, proper waxing provides paint protection.
    thanks sir Ghosthunter. how bout yung carnuba cleaner wax? yun kasi yung nabili ko and im not sure if it's different with the regular carnuba wax...Ok po ba yun gamitin lagi?or would that fade my paint kasi cleaner siya?
    Jan 2011
    Problema ko din yan sir kung ano ba tlaga magandang gamitin...gusto ko lang matanggal ung maliliit na gasgas gawa ng naipupunas na alikabok.nakabili ako dati ng 3M na paint protector,pakikintabin tlaga pero di nya kayang tanggalin kahit maliit na gasgas....
    Quote Originally Posted by JhayVitara View Post
    Drying wiping dust and dirt is just like wiping your car's paint with a fine sandpaper. Not really the best idea especially if you do it often. The paint's shine will sooner dull.
    Best to float the dust and dirt off with water, just plain water. Just run clean water over the area and lightly wipe with you hand to remove the remaining dust that the water did not clean off.
    Also avoid waterless cleaning products, these do more long term harm to your car's paint as well.
    Mar 2005
    Nandito na lahat. May list din ng mga Cleaner Wax/Sealant or Finishing Wax or Sealant.
    The Difference Between a Cleaner/Wax and a Finishing Wax
    http://www.autogeekonline.net/forum/...shing-wax.html
    Jan 2011
    sir problema ko po kung pano matatanggal ung mga swirls ng paint.ung pasok sa budget...DIY po ako lage sa vit ko kaya gusto kong mag try ng bago..ano ung pnaka basic na product to lessen those swirls or to completely removed those things?
    Quote Originally Posted by whilmeister View Post
    Some wax products have a polishing component mixed into it. This helps remove minor stains from the paint. It supposed to be a effort and time saving product. But frequent use of this will thin out the clear coat or the paint itself, especially on edges or corner portions of the car body.
    Personally, I prefer using the basic wax products.
What's the difference between carnuba carwax Cleaner and the ordinary wax
