Results 1 to 10 of 26
- Sep 2006
- 40
July 28th, 2007 08:36 PM #1mga preps, pano ba to look 4x4 iyong stock na 94 4x2 hi lux?
Gusto ko kc pataasin ng konti iyong looks nya... tnx
July 29th, 2007 02:42 PM #2
You can adjust the torsion bars and put shackles at the rear.
But i think it will not be as high as 4x4 hilux because of the difference in platform.
- Jun 2007
- 207
July 29th, 2007 09:38 PM #3sir dong,
sa front pwede un torsion bar lift pero ttigas un ride..pnka mgndang approach dyan is if may budget ka pwede ka mg downey 2wd lift kit..around 3 inches ata..tpos sa rear pwede e spring over..then palit kna ng tires pwede kna gmit ng 32-33 inch tires ...as for power loosing on larger tires..no probs yan kc hliux dami pwede gwin pra ma restore un lost power by having larger diameter tires...
- Sep 2006
- 40
July 29th, 2007 09:46 PM #4Sir mga magkano budget para dito? sa downey 2wd lift kit..around 3 inches ..tpos sa rear pwede e spring over..
San pwede Bumili, magpagawa o magpa set up nito....
Salamat po...
- Sep 2006
- 40
August 4th, 2007 10:34 AM #5how about iyong sinasabi na palitan iyong hanger sa likod at adjust ng torsion bar sa front? ano performance kung ganito set up? 2.4D lang kc engine na 2L. salamat
- Jun 2007
- 207
August 4th, 2007 06:36 PM #7body lift kna lang bro f medyo low budget approach tpos trosion lift ka..meron ata available na torsion bar na pwede gmitin na up to 2 inch sya pwede..downey ata brand nun...
- Sep 2006
- 40
August 6th, 2007 06:31 AM #8LYTSPID ano the best na procedure kung body lift?
[SIZE=4]mga 2 inches lang siguro itataas,[/SIZE] [SIZE=4]ano best option.....? tnx[/SIZE]
but I stll consider the two option...
Eto mura lang pero sacrifice ba ang ride?
(You can adjust the torsion bars and put shackles at the rear)
may presyo pero guaranteed ba ang good ride?
(downey 2wd lift kit..around 3 inches ata..tpos sa rear pwede e spring over)
ano nga pala difference kung shackles o mag spring over ako sa likod?
ano pros and cons? tnx....
basta iyong likod e pwede kargahanng medyo mabigat....
salamat
- Sep 2006
- 40
August 6th, 2007 06:34 AM #9Ano nga pala pagkakaiba kung spring over o shackles ang ilalagay ko sa likod?
- Sep 2006
- 40
August 6th, 2007 06:35 AM #10ano nga pala difference kung shackles o mag spring over ako sa likod?
ano pros and cons? tnx....Last edited by dongbadz; August 6th, 2007 at 06:45 AM. Reason: delete
as an aside, in the olden days, anyone who does not move 'ala luksa during Holy Week, especially...
Traffic!
