Results 1 to 10 of 11
- Sep 2015
- 20
October 1st, 2015 07:53 AM #1Hello detailing masters.
What pads do you recommend as a starter must-haves for random orbital polisher use?
Thanks.
October 1st, 2015 09:47 AM #2
This will depend on your intended use. If your car is relatively new a polishing and finishing pad is enough.
But if you intend to do heavy paint correction, consider a compounding pad in addition to the pads I mentioned above.
And also what products do you intend to use with these pads?
- Sep 2015
- 20
October 1st, 2015 11:24 AM #3Relatively newly painted and scratchless paint. No heavy paint correction needed. I guess basic wash application to minor pain correction lang ang need ko. Also, I might be doing some muffler polishing and plastic headlights/tailights restoration.
Re products: I have not decided yet sir, just starting up. Perhaps you could also make suggestions with theses.
Thanks Kitoy22!
Thanks Kitoy22!
October 1st, 2015 11:49 AM #4
If that is the case, your good with a polishing pad and finishing pad, you may not even use your polishing pad if its a newly painted car, unless the finish after painting is not done well.
As for the products, i recommend megs 205 or sonax perfect finish. These are medium polish that can finish very well, gives you a wider range of cut if you need it, just play around with your pad combinations.
- Sep 2015
- 20
October 1st, 2015 12:02 PM #5Kitoy22 could you give me a specific brand and model of the pads?
I'll look into the products you mentioned. Thanks. :D
October 1st, 2015 12:08 PM #6
- Sep 2015
- 20
October 1st, 2015 06:48 PM #8
for starter kit, get 2 orange, 2 white, 1 black lake country pads and your good to go
for polishing of minor scratches and swirls, use the orange pad. for all in one polishes, use the white. for applying glaze/wax use the black one. read further in autogeek.com.
it's the orange pads that i use more often
- Sep 2015
- 20
October 2nd, 2015 02:12 PM #9why 2 of the orange and the white? where do you buy them and how much? thanks monty. :D
October 2nd, 2015 03:21 PM #10
because you will use more often the orange and white pads. during polishing, polish residue accumulates in the surface of the pad and it lessens its abrasive efficiency. you need to change to a fresh pad. for a small sedan, 1 orange or white polishing pad may suffice but if you have bigger car like an suv or van, you need at least 2 of each.
a relative in the US bought them for me. check ginnova here in tsikot or in olx, he might still have some pads for sale.Last edited by monty_GTV; October 2nd, 2015 at 03:28 PM.
VinFast VF 3
