Last week pinapaint ko ang coche ko. Sabi nila 3 to 4 weeks daw bago matapos.
Ano ba ang stages ng repainting at ilang araw kada stage? Gusto ko lang malamang kung bakit ganun katagal.
Salamat!
Salamat!
Change color ito. Nagsanding sila hanggang primer. Mga ilang araw lang tapos na.
Ano bang stages ng painting? at ilang araw bawat isang stage.
Mam Yves, ok po yong matagal dahil they adhere to the right procedure ng auto painting....the right procedure po ay tamang pag kaka dry ng paint whatever paint that is. YUn pong madaling magpatuyo ay madali ring kumupas o matanggal ang paint o magbulutong..yung pong may bula o kaya ay mga pinholes kapag natuyo dahl nagkaroon ng trapped moisture. Kung may tanong pa po kayo ay maaari kayong magsadya dito sa amin sa FRankline dent repair sa 31 examiner st. west triangle sa qc.
here's a good article.. How To Paint A Car - Auto Painting Tips - Mopar Muscle MagazineChange color ito. Nagsanding sila hanggang primer. Mga ilang araw lang tapos na.
eto ang mga stages based on the article. how long does each stage last? depend sa condition ng sasakyan mo.
1. Repair Stage
- Rust removal
- Metal works
- Welding
2. Body Straightening Stage
- Block sanding
- Filling
- Block sanding
- Applying guide coat
- Block sanding
3. Painting stage
- Masking
- Wash, Clean, Wipe
- Priming
- Drying
- Base coat
- Drying
- Top coat
- Drying
4. Finishing stage
- Wet sanding
- Polishing
- Buffing
Straightening the panels is likely the most time-consuming part of performing automotive bodywork. While some panels may be straightened with a hammer and dolly, most require filler to be perfect. It takes many hours of spreading body filler, sanding, and repeating the process to ensure a panel's straightness, and, again, some specialty products and tools are required.
^you're welcome.
since brand new ang kotse mo, di na need ung Repair Stage at Body Straightening Stage, except for the Block sanding part.
change color (external only), i think kaya ng 2-3 weeks.. change color (external and internal), 4 weeks should just be right..
but i won't complain as long as pulido ang trabaho. saan shop mo pala pinagawa? how much and how long ang warranty?
Sa Hyundai shaw. 30K. Warranty itatanong ko pa. Thank you for bringing that up.
One year daw ang warranty. Is that okay or should I ask for longer warranty?
One year warranty daw. Okay ba yon? Should I ask for a longer warranty if I paid 30K?
If your car is brand new, it can take one week for a good professional car shop to finish everything.
