Page 128 of 296 FirstFirst ... 2878118124125126127128129130131132138178228 ... LastLast
Results 2,541 to 2,560 of 5910
    Sep 2006
    #2541
    Quote Originally Posted by theveed View Post
    Swirls are caused by physical debris between the surface of the paint and towel, it has nothing to do with QD type. If your cloth isn't clean or the surface has hard debris and it transferred to the towel, swirls occur. Using a high lubricity QD will only minimize its damage but it won't be the one CAUSING swirls regardless of what you use.
    thanks for the clarification, cguro nga madumi lang MF ko, pero malaki talaga difference ng Mothers Showtime kesa dun sa Zymol QD
    May 2007
    #2542
    Quote Originally Posted by drey View Post
    sir liv,
    how much did you pay for the job?
    1,2K for the innova. BTW, lady tsikoteer po ako.
    Jun 2007
    #2543
    Quote Originally Posted by liv View Post
    mam, gano po katagal gnawa paint protection sa car nyo? 1-2hrs? TIA
    May 2007
    #2544
    Quote Originally Posted by clreceno View Post
    roughly 2-3 hrs.
    Aug 2007
    #2545
    What if you're ride is a 99 model and may mga aayusin sa loob like carpets, leaather seats ets.. Magkano kaya aabutin or inaayos din nila sa loob yun? just need a ballpark figure sa big bert's. I've noticed puro bago kasi yung mga ride nung nagbibigay ng feedback.
    #2546
    medyo mahirap pala palitawin ang shine ng puti. although lumabas naman din ang luster niya
    Jun 2007
    #2547
    *baludoy good job sir ang ganda 1-2-3 step ba ginamit mo diyan?
    Jun 2007
    #2548
    kakatapos lang ginabi na hehe
    2-3 step ng Megs DC
    #2549
    Quote Originally Posted by washburn View Post
    hindi bro. i just used turtle wax on the car. inuubos ko lang iyong naka-stock dito sa bahay. sayang din naman kung di mapakinabangan eh
    #2550
    Quick question lang po from an uber newbie.
    1. When you use QD + MF....dapat ba tuyo ang MF?
    2. When you remove then buff ang wax... syempre dapat tuyo din ang MF?
    Takot kasi akong magkamali e.
    Thanks.
    Aug 2006
    #2551
    Quote Originally Posted by a4Tech View Post
    You can use wet or dry MF for QD.
    Example: If you use "Eagle One Wax as U Dry" you can use wet MF.
    Thanks.
    I buff with dry MF, kasi kita mo agad ang results. If you use wet MF, more likely magkakaroon ng contamination yung buffing MF mo especially kung yung wax mo ay may white residue.
    Sep 2006
    #2552
    Thanks.
    i think it is much better if the MF is dry for both QD use and buffing use
    #2553
    We invite all tsikoters to come and visit our new car wash and detailing shop
    at Aseana Powerstation, Macapagal Avenue.
    R-1 Autocycle Wash and Detailing
    Detailing powered by Meguiars
    We have a special promo this month
    50 pesos car wash with tire black and vacuum already.
    discounted detailing this month
    You can look for us at the back of Yellow cab and Shell Macapagal Ave.
  14. #2554
    Sir can you share the tools that you use? Do you use washmitt, waffle weave microfiber? Is your tire black silicone based or water based? What car shampoo do you use? Do you use a foaming machine.
    Thanks.
    Nov 2006
    #2555
    Where To Start
    The interior is a good starting point, so the dust and dirt you brush out won't settle on a pristine exterior. Remove any floor mats and give the carpeting and upholstery a good vacuuming. Also vacuum the dash and rear parcel shelf. Move the front seats full fore and aft to get to all the accumulated dirt and loose change. If the carpets are clean except for a minor stain or two, use a foaming cleaner to get them out. Saturate the stain with cleaner, working it in with a damp sponge. Let it sit awhile and then blot it out with paper towels or a dry cotton cloth. Repeat if necessary, and then go over the area with a damp sponge before final blotting. Don't oversaturate the carpet and risk getting mildew.
    You can repair burns and holes in your carpet by cutting out the offending area with a razor blade or scissors. Then cut a similar-size piece from a hidden spot, such as underneath the seat, and cement it in place using a water-resistant adhesive. Blend in the repair by brushing the nap.
    Wash the floor mats, if they're rubber, and apply a dressing that does not leave a slippery finish, for obvious reasons.
    Clean interior hard surfaces with a damp cloth and a mild all-purpose cleaner such as Simple Green, diluted about 10:1. If you have vinyl-covered seats, use a conditioner made for that material. Avoid products that give a high-gloss, slippery surface, so passengers won't feel like they're on a roller coaster. If you have leather upholstery, dress the surfaces with a leather conditioner. Never use a vinyl product on leather.
    Worn or torn areas of vinyl can be repaired using kits made for this purpose that are available at auto supply stores. Repairs are made with a patch that lets you match the color and grain of your upholstery. Worn areas of leather can be touched up with dyes or a high-grade shoe polish. Just make sure you match the color as closely as possible.
    The dash presents a special challenge, with buttons, crevices and bezels that you can't get to with a cleaning rag. You can blast dust and dirt from these areas by using small cans of compressed air made for cleaning camera and computer equipment. Cotton swabs also work well here. Pay attention to the cleaning products you use on your dash. If your dash has a flat finish, don't use a product on it that will leave you facing a shiny gloss.
    Clean air vent grilles with cotton swabs and brighten them up by misting on some spray-on vinyl/rubber dressing or accent spray-just a touch. You can also use these products to cover up light scuff marks on wood trim. Spray the stuff on a soft towel and then apply it to the wood.
    Clean glass or plastic gauge lenses with a glass or plastic cleaner, not wax. Pull off any removable knobs to clean the bezels underneath. Ever wonder where the haze on the inside of your windshield comes from since you don't smoke? It consists of plastisols given off as the plastics used in many new cars slowly cure. Not to worry-a good glass cleaner should remove it. If your windows are really cruddy, you may have to resort to stronger measures, such as scrubbing with 4-ought steel wool.
    A Word Of Caution
    If you have aftermarket window tint film, it may be degraded by cleaners that contain ammonia or vinegar. Factory tinting is in the glass and is not affected by these cleaners. One trick used by some detailers for the final touch on window glass is to rinse it down with seltzer and do a final wipe with a ball of crumpled newspaper.
    When it comes to first impressions, nothing makes a hit like a jewel finish. But this is possible only after any paint problems are corrected. Just about all finishes today are a 2-step (color) basecoat and a protective clearcoat. The top clearcoat is only about 2-3 mils thick, and when it gets scratched or abraded it refracts light and the color coat underneath doesn't shine through clearly. It's like looking through a scratched or foggy lens.
    To evaluate your paint, first wash your vehicle. Work in the shade and make sure the surface is cool. Use a carwash soap, not a household detergent, and work in sections, from the top down. The lower panels tend to accumulate more abrasive dirt. To do a final rinse, remove the spray head from the hose and flood the finish. The water will tend to run off in sheets, minimizing spotting. Dry with a good-quality chamois or a soft thick-nap terry cloth towel.
    Don't forget the wheel wells. Get the crud out with an all-purpose cleaner and a good high-pressure dousing. After you've finished washing your car, apply a vinyl dressing to add some snap to the wells.
    Wash the wheels (make sure they're cool) with a brush made for this purpose, but do not use acid-based cleaners on polished alloy wheels or wheels that are clearcoated. You can use these cleaners on rough-textured alloy wheels. Chrome wheels can be gleamed up with metal polish or glass cleaner.
    After washing the car, inspect the paint. Stains and scratches can be attacked with a good clearcoat-safe cleaner. The worse the problem, the more aggressive the cleaner needed. Start off with the least abrasive product and gradually move to coarser cleaners as required. Then machine buff.
    Polishing and/or waxing is next. Be sure to include doorjambs, and the areas beneath door hinges and behind bumpers. Minor blemishes may be neutralized by wrapping a cotton cloth around your index finger and burnishing the polish into the finish.
    Polish not only gives the finish its gloss, but it feeds the paint with oils to prevent it from drying out. Polymers in the polish fill in minute scratches in the clearcoat layer, restoring its clarity. If you machine-buff the polish/wax to a high luster, go with an orbital rather than a rotary model, which would be more likely to burn the paint. Treat the plastic chrome on today's cars as if it were a painted surface and protect it with a light coat of wax.
    Avoid getting wax or polish on rubber and flat black plastic areas (clean them with a nongloss product), door handles and emblems. If you do get a wax stain on rubber trim, spray it with a mist-and-wipe product and wipe it down with a terry cloth towel. If that doesn't do the trick, this usually works: Microwave some peanut butter and apply it to the stain with a soft toothbrush. Peanut butter's oils dissolve the wax and it's abrasive enough to lift the stain (but it can stick to the roof of your car).
    If you get a polish/wax residue around emblems or in crevices, break out the cotton swabs and toothbrushes. It's important that you first wet the area with a mist-and-wipe product such as Meguiar's Quick Detailer. Never brush on a dry surface.
    Moving underhood, protect electronic components by wrapping them in plastic. Then spray on a diluted all-purpose cleaner, hosing it off with light water pressure. Vinyl/rubber protectant will dress up nonmetal areas. Let it soak in if you like the glossy look, or wipe it on and off for a more matte finish.
    All that's left now are the tires. Clean them first-whitewall tire cleaner works even on blackwalls-and then apply tire dressing. Here again, to get a gloss finish let the product soak in, or for a matte look wipe it on and off with a cotton cloth. Be sure the tires are dry before driving off, or you'll spatter your nice shiny finish. And maybe even your neighbor.
    How It Works: Clearcoat Paint
    Most modern cars use a clearcoat paint system. The pigmented layer of paint, whether a solid color, metallic or pearlescent, is covered with a layer of clear paint to provide a higher gloss and a "deeper" look. So far so good.
    But the surface of any paint, even clearcoat, is vulnerable to scratches and oxidation. In the past, abrasive rubbing compound could be used to polish out these imperfections. Clearcoat is thinner, and using abrasives is trickier. Removing too much paint will leave the pigment layer exposed, necessitating a respray with more clearcoat. The recommended procedure for oxidation and haze is to use a chemical cleaner or cleaner wax. Look for products that specifically say they are appropriate for clearcoat paint on the label. Light scratches can be buffed out with very mild polishing compound. Do not use rubbing compound on a clearcoat finish. Scratches that go through the clearcoat layer cannot be polished out. You'll either have to live with them or respray the entire panel.
    Sep 2006
    #2556
    here's another newbie question:
    where can one get an orbital buffer?
    i'm scared of going the "converted grinder" approach.
    #2557
    don't use a converted grinder. masyadong malakas ang motor and torque. you're liable to do more damage than paint correction.
    maybe, just maybe if you can power it down but then there's a Makita Rotary and variable speed pa...
    I'd rather opt for ROP muna if you want to learn using a machine.
    anyway, to answer your Q, I'm not sure about the availability but do try to check out Bosch and Dewalt. I think sa Autoplus meron PC but that was last year pa ata.
    #2558
    Pano kaya yung paint ng Mazda ngayon? Parang sobrang nipis
    #2559
    Finally i mustered enough courage to detail my ride last saturday (9/15).
    There was a slight drizzle outside kaya i have to do my detailing sa loob ng grahe (whew sikip).
    Anyway i started 10:30 AM and finishished mga 8PM na.
    Lessons learned: Pag sinabi nyong in thin coatings...talaga pala dapat thin coatings hehe.
    My tools:
    1. Mom's Phase 1
    2. Mom's Scratch Remover
    3. 3M IHG (Sachet)
    4. Simoniz Diamond Wax (sealant 2 coatings).
    5. Armor All APC
    6. Eagle One QD
    7. Megs applicator pads
    8. Microtex ultra plush
    9. California car duster
    Grabe i almost fainted sa pagod kaka buff then i finally got the right amount of coating na madali i buff.
    After 8PM i decided to let the sealant cure overnight then i reapplied it 8AM sunday.
    Actually i have 3M Liquid Wax pa...hindi ko na kinayang ilagay pa kasi may lakad pa kami ni bossing kumander.
    #2560
    and finally the reflection shot...
    Comments are welcome.
    Thank you for viewing.
