Results 5,581 to 5,590 of 5910
July 11th, 2010 05:14 PM #5581
mga boss pwede po ba magtanong. gano katagal ang interval pag kunwari nag pa machine buff lang ako last month..kelan po ako pwede mag pa buff ulit??ung .. yung jebs kasi ng ibon ang hirap na matangal..iniisip ko baka ok nmn ipa buff na lang siya.. salamat..
- Aug 2009
- 1,553
July 11th, 2010 05:36 PM #5582It depends on how you define machine buff
if its
machine wax = meaning application of cleaner wax and then removed via machine using a pad then you can have this done every month
2 step = meaning using a polish and then machine wax, then you can have this done every time you get a lot of swirls on your car
3 step = meaning using rubbing compound, polish and machine wax then i would suggest you only avail of this service only when desperately necessary since this really does remove a considerable amount of clear coat
Then again, bottom line, it still depends on the level of the detailers skill, my Bf recently saw a Revo that was really shiny and glossy and it was 3 stepped 5 times and it still has some orange peel and i've seen a car 3 stepped only thrice and it already striked thru the primer
July 11th, 2010 07:30 PM #5583
so ok lang pala mag pa machine wax every month...akala ko po parang mga 4 months bago ako pwede mag pa buff..may nagsabi kasi sa akin na pag lagi daw ginagawa yun parang mawawala daw yung top coat.kasi hindi po ba after mag buff mainit init pa po yung paint..kaya ganon po pagkakainitindi ko regarding sa pag buff..thanks po.
July 11th, 2010 07:32 PM #5584
July 11th, 2010 07:42 PM #5585
July 11th, 2010 07:45 PM #5586
- Feb 2010
- 234
July 11th, 2010 08:23 PM #5587Hi all,
Will Klasse AIO be able to replace a true polisher for nothing more than the most light swirl marks/bird dropping etches and water marks?
I'm seriously considering using a polish to remove light scratches, but apprehensive about the results since I don't have access to a RO machine polisher and intend to just use hand polishing.
TIA
July 11th, 2010 08:41 PM #5588
July 11th, 2010 08:50 PM #5589
Sir proper washing technique using MF washmitts, 2 bucket method and MF or waffle weave drying towel para ma minimize ang cause ng swirl marks. Everytime na nag reremove ka ng swirl marks little by little nababawasan ang clear coat ng paint.
Kung hand application ok ang Megs Swirl X and maintain with Wax.
July 11th, 2010 09:38 PM #5590
*jmpet626
sige try ko sila tawagan tomorrow kung nagbenta sila. kakatamad kasi to my transformer pa..ehe
*madkatz.
meaning yung AG SRP sealant na din yun? hindi ko na pwede lagyan M21 pag nag lagay ako ng AG SRP... balak ko kasi pag ka polish ko ng AG SRP , lagyan ko ng M21 tapos yung nxt gen tech wax 2.0 na paste. pero sympre caly muna..
cge yung bosch na lang muna bibilhin ko pang wax at pang polish ko yun...
eto ba ung sinasabi mong WP1300
http://www.blackanddecker.com/produc...view=4#details
ibang model n yan 11amps parang malakas na talaga yan...hehe
pag nagamit naman ng rotary diba dapat light pressure tapos wag papatagalin sa isang place. yun rpm lang hindi ko alam kung gaano kabilis
VinFast VF 3
