Results 1 to 5 of 5
    guys, what can i do kasi yung hinges ng doors and sa hood medyo sumusikip na buksan at isara because of some rust forming... ano po maipapayo sa isang nalulungkot at namomoblemang tsikoteer...
    Dec 2003
    temporary solution, spray some WD40 on the hinges..
    permanent solution: remove the hood or doors itself and remove the rusts inside by sanding then repainting uli..matrabaho tol
    Feb 2005
    jv..
    try mo muna spray it with WD40 to loosen the rust and play with the hinges by open/closing it a few times. when you see the rust dripping na, spray mo ulit. don't forget to wipe off the drips kung meron sa body ng car mo.
    thanks for the advices... will do these things...
    or try grease..kasi yung wd40 madaling matuyo than good old fashioned grease
what can i do?
