Results 1 to 10 of 24
May 3rd, 2006 10:49 PM #1
hey sirs, ask ko lng if you have an idea where to find lowering springs for sentra 05, if there's any.
and which is better, clip or compress.
May 3rd, 2006 10:56 PM #2Originally Posted by snker
May 4th, 2006 12:36 AM #4Originally Posted by snker
May 4th, 2006 09:27 AM #6Originally Posted by snker
Compress (or heating the spring) will change the properties of the metal of the spring. It will become brittle at the point where it was heated and might snap/break anytime.
Clips will rattle when you drive over any irregularities on the road. These also move as the spring is being compressed & uncompressed. The clips might end up on one side of the spring or totally drop off your spring resulting in one corner riding higher than the others.
Cutting is another option and I don't recommend it too because the cut off side of the spring will not seat properly. This might result in the spring falling out of it's perch.
May 4th, 2006 09:32 PM #8
try mo si speedyfix.. when i had my lancer, i have asked him if he could get an H&R springs.. it would probably cost you about 10k (or less). pinaputol ko yung springs ko dati, which will give you the look you need pero madadalas kang magpalit ng shocks since the OEM springs was made for the weight of the car and trying to alter it will give you problems since naiba na yung "properties" ng support for the car (e.g. springs).
May 4th, 2006 10:02 PM #9
wag ka magpaputol, clip, or compress, tama si ghost hunter, pinagisipan ko na rin yan eh ung sa civic ko 2003, whitelines ung skin 7k ko nakuha, brandnew, pero mag h&r ka or tanabe, para iwas tagtag, kasi ung sakin grabe sa tagtag!!
May 4th, 2006 11:09 PM #10Originally Posted by mgbrillo
Daming issue ng SU7:grin:
Xiaomi E-Car
