Results 1 to 20 of 20
    Namumuting Side skirt and chin
    nung SiR ko ano kayang magandang solusyon?
    Flat black kasi ang color
    balak ko na ngang pintahan eh
    Ano kaya?
    TNX!!!!!!!!! :D
    Kung papipinturahan mo, flat black din dapat. Yung ibang talyer kasi gloss, eh. Hehehe. Panget ang effect.
    Ask theveed! PEANUT BUTTER ang katapat nyan! no joke. I've read it in his forum before. :D
    yup....beanut butter. ladies choice ata
    sir be sure to primer it with PP primer or polypropelene para flexible yung primer hindi mag crack yung paint na flat black
    or maybe you can try to painting it same with your car's color "body color" it has a different effect and look. ganda rin... parang lumalaki yung car and mas malinis tingnan.
    well i think ill go for "ludy's peanut butter"
    Medyo mister budget guy tayo eh TNX!!!
    Anong pangpahid sa peanut butter, tinapay?:D
    pandesal ata max he he.
    Check mo site ni david. May instructions pa ata kung paano nya ginawa yun. Ayos nga logic nya kung bakiyteffective yun eh. Something to do with the vegtable oil base ata.
    hold your horses... depende yan.. if your chin and side skirts are untreated rubber (like "common" moldings), peanut butter (or any other vegetable oil) will be able to absorb the white residue and restore it slightly...
    BUT...
    if it's painted flat black, your paint is failing and only a repaint will do its job...
    o nagutom tuloy ako, gusto ko lily's peanut butter yung ma oily he,,.he
    Quote Originally Posted by theveed
    I've had great success getting rubber, vinyl and plastic back to it's original color by using Mother's Back-To-Black.
    It's a gel that restores the black to your non-painted surfaces. Very easy to apply, which is why I've stuck with it for a few years now. Especially helpful when I need to get wax off rubber/plastic pieces I had accidentally gotten wax on.
    Fairly cheap, plus the 8 oz. bottle will last you a while too!
    I use Meguiar's Trim Detailer...
    Pick one up sa Hans Tools sa Shangrila Mall.
    Stoner Trim Shine is far superior to Mother B2B and Meg TD... no need to buff pa...
    Thevs, first time I heard about that...
    Saan nabibili yan?
    True Value lang meron eh...
    Mother's Back to Black needs to be buffed? All I do is to wipe it on, and it's good to go!
    I'll give Stoner Trim Shine a try too. Which one is more expensive?
    you're not supposed to leave it on coz it'll attract dirt... B2B doesn't clean trims, it just dresses it... it's a good product, but there are better ones... the most popular trim restorer in the US is a cleaner + dye product called Forever Black... it's the best for plastic, unpainted bumper restoration...
    Since you're in the US, I suggest you purchase them online, Stoner's Invisible Glass is also considered to be one of the best glass cleaners out there... http://www.stonersolutions.com
    I believe that they give out special offers like buy one trim shine and get 2 cans of invisible glass free, etc... Check your Motor Trend, Car and Driver and Automobile magazine ads... they usually have it there...
    Ooh, learn something new everyday!
    I have to bonk myself over the head cause it turns out I never read the instructions for the Back-to-black right! theveed, you're right, you do have to buff after applying it!
    I seem to be very fortunate that my plastic trim hasn't attracted that much dirt over the years
    Thanks for the tip! Very much appreciated! :D
    sir theveed,
    how much po ung Stoner Trim Shine?pwede ba siya dun sa black plastic that holds the cover of the side mirror?and other exterior plastic stuffs like ung grill etc?
    It'll work for any rubber/plastic molding. As for the price, check it out sa True Value nalang. I didn't get mine locally.
