Napansin ko kasi medyo umiitim na yung interior kisame ng oto ko (driver's side) dahil parati akong naka bukas ng bintana during the christmas season (sarap ng hangin sa roxas boulevard eh).
Any DIY products I can use to clean it?
BTW: yung ceiling is parang velvet, hindi sya leather.
I used over the counter fabric/carpet cleaner. Eto ung may foam kapag ini-spray. I think mga P295 sa Handyman. Forget the brand pero marami sa market na ganitong type ng cleaner.
I usually spray 1ft X 1ft ceiling area (one at a time), then wait around 1 minute, then brush the foamed area by soft tootbrush (alalay lang sa diin).
I used damp cloth then dry cloth for final touch. Maganda naman ang lumabas na resulta at pantay naman ang kulay ng entire ceiling.
delikdao sa suking carwash shop... baka sumablay... happened to my corolla when I was in college sa carwssh shop ko lang pinatira... ayun sa sobrang din nakalbo yung ilang spot ng ceiling badtrip.
mas ok saprofessional detailing shop na lang. Pa interior detail na lang para pati carpets and door sidings malinis na din
ako pag may time interior detailing na sa Bigberts
Pag na-saturate ng sobrang daming tubig yung headliner, pwedeng maapektuhan ang adhesive nito. Ang result, parang nakalawlaw yung liner sa ceiling kahit tuyo na.
Either have it professionally done, preferably with the us of an extractor, or DIY mo using different upholstery cleaners available in hardware stores.
If you favor the foam type cleaners, then, Power Out is a good choice. Zap is also good. The trigger spray has an option na pwedeng regular spray or mild foam. If you have access to all-purpose cleaners by Meguiar's and Eagle One, then these are excellent choices as well.
Originally posted by Supierreman delikdao sa suking carwash shop... baka sumablay... happened to my corolla when I was in college sa carwssh shop ko lang pinatira... ayun sa sobrang diin nakalbo yung ilang spot ng ceiling badtrip.
what brush, rugs, foam, etc. to use so this will not happen, balak ko kasi diy lang?
