Results 1 to 11 of 11
    Mga bossing;
    When I feel the surface of my car magaspang. di naman dating ganito yun eh.
    Nung nagpagawa ako sa talyer mayroong pinipinturahan sa malapit ito ba yung cause nun?
    What should i do para bumalik yung smoothness nya. Pinunasan nang father ko nang terry cloth mukhang nagkaroon nang swirl marks.
    Please advise.
    Thanks.
    If I remember it right, theveed did clayed my rough paint areas. Dinala ko na lang sa Big Berts at dun pinagawa. :D
    I have some stuff here pwede kaya DIY na lang.
    I have a orbital polisher and some wax cleaner, glaze and wax.
    Can I remove it by using them. Please advise kung ano pa kailangan ko.
    Thanks.
    Mano-mano yung clay para maalis yung pinong pintura. If you could test removing it by your own nails, matatanggal yan. Wash the whole vehicle to get rid of the dirt first. Meron silang hinahalong liquid para madaling ipahid yung clay bar to the affected part.
    No wax or polisher was used. Buong body pa naman yung sa akin. Pati bubong di pinalampas.
    Boss ano magandang clay na gamitin.
    Nakakita ako nang soft99 w/ QD. ok ba to?
    Thanks.
    Yan ang di ko masasagot, you will have to wait for theveed's reply. :D
    tama ka, you most likely have paint overspray on your car. it can be DIY'ed with an orbital buffer and polish, but takes a lot of effort. claying is a much easier and pain-free solution.
    btw, yung talyer ang ipagbayad mo ng detailing fees mo. sila yung tangang nag-overspray ng sasakyan mo.
    Soft 99 makes good claybars. Just use the QD as lubricant while claying.
    1. Wash your car.
    2. Slice the Soft 99 claybar into 3-4 pcs. YOu will be needing just 1 slice.
    3. Knead the claybar until it is soft like modelling clay
    4. spray QD on the surface
    5. Gently glide claybar on QD'ed surface like you are just wiping.
    6. Knead the claybar once in a while to expose unused portions.
    Note: kung masyado nang tumagal ang overspray, it might be difficult to remove them with clay. You might need to resort to wetsanding.
    Call us 4150979 if you still cant get it done and we would gladly help you.
    Boss blackMagic;
    Madami kasing klase Soft99. Ano yung para sa Light Blue na color.
    Thanks.
    Just dont get the white one.
    Dec 2004
    claymagic, nasubukan ko na... epektib.. tanggal lahat nang mga microdusts..
When you feel the surface of your car magaspang. What should i do?
