mga sir pano po ba iflush ung radiator? gsto ko po palitan ung coolant ko po. pag naglagay po ba ng coolant dapat lahat ng ilalagay sa radiator pure coolant lang? or kainlangan po bang haluan ng tubig? thx
To drain the radiator, unscrew the drain plug located under the radiator.
When adding coolant, follow the recommended mixing ratio written on the bottle/container. Most would be 50 percent water with 50 percent coolant.
Pure concentrated coolant in your radiator (without water) will result in overheat.
