Results 1 to 5 of 5
- Nov 2009
- 50
November 15th, 2009 07:44 PM #1That's my observation in my auto, when i'm running fast, the air is cool, otherwise it is normal. Pwede bang i-adjust siguro ung automatic ng aircon ko? Baka naman kasi d lang siya umiikot pag idle or mabagal ang takbo ko. (un fan sa aircon sa tabi ng engine). What do you think?
- Nov 2009
- 2
November 16th, 2009 01:37 AM #2I'm not sure but I read somewhere na the reason why it's cooler kung tumatakbo ka na ng mabilis is more air is passing on your condenser kaya mas madaling palamigin ng aircon system mo.
Anyways, pinacheck ko na rin yung sakin kanina, ang problem lalamig lang pag tumatakbo na ko ng mabilis hanggang sa nawala ng tuluyan kanina. Nakita ang daming leak ng evaporator ko. Damage is 8k. Oks na rin since ang diagnose ng ibang shops, compressor, malamang tumataginting na 18k yun. Sa Ceejay's Las Pinas pala ko nagpagawa.
- Aug 2009
- 31
December 11th, 2009 04:50 PM #3undercharge ang system o loose compression ang compressor,check for leak baka kaya nag a-undercharge ka eh may leak ang system mo sa loose compression naman kung gusto mo makasiguro i check mo compressor mo using thumb method tanggalin mo yung fittings ng discharge line mo ito yung hose sa pagitan ng comp at condenser then patakbuhin mo makina at irekta mo yung pressure switch at i-on mo ac, takpan mo ng hinlalaki ang discharge hose kung kaya mo pigilan ang pressure, loose compression ka na
- 48
December 12th, 2009 05:45 AM #4the first cheapest thing to do is check if your aux fan motor sa condenser is running at its optimal speed (or is it running at all?) if its ok then have your system cleaned if matagal mo na ito hindi napapalinis... last and expensive option is a compressor replacement nga.
hth
December 12th, 2009 08:15 AM #5
pag mabilis lang naman,e.. so condensers yan..sobrang init lalo na kapag nattrapik..check your fans both main and aux...
kung compressor, dapat pag ni-rev mo, lalamig cya...
2026 Mazda CX-5
