Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Jul 2005
    My ride is a Nissan and my aircon setting is at 25 degress celcius. I find this setting to be the most comfortable. Not too cold and not too warm. Kaya lang whenever i take my car for PMS, pagkuha ko the aircon is down to 18 degrees celcius, which is just freezing for my taste. I'm just curious why the guys at the casa always put it in this setting. What's the benefit in setting the aircon at higher or lower temperature setting?
    Kayo, ano po setting ng aircon nyo?
    probably they also test the cooling capacity of your a/c by setting it at higher temp. but hindi nga maganda to leave it that way if your preferred thermostat is only at 25 degrees
    mine is not digital, a simple slide switch which I normally set at 30-50% lang.
    i dont know exactly the temperature readings pero i just set my thermostat at around 1-2pm.
    Sep 2005
    pag pinasok kasi sa CASA.. dyan natutulog yung mga tech pag lunch break.. kaya todo aircon..
    Quote Originally Posted by 1D4LV View Post
    vlad, more than 50% malamig na rin yan. kahit tanghali. have you tried at 10 o'clock at least?
    Aug 2005
    Sa Avanza, Fan at 2, Thermostat at first click from off.
    Sa ZZ, Fan at 1 or 2, Thermostat at minimum.
    May 2008
    Sir Meledson, mas matipid ba pag ganyan setting sa avanza?
    Yun kapatid ko kc pag gumagamit yung Fan sa 1 lang then yung thermostat pagkataas taas...
    Kala namin kc mas matipid pag fan at 1 eh...
    Sep 2005
    ako fan at 2, thermostat at 9 o'clock
    Sep 2004
    Fan - set at maximum after start-up, then number 2
    Thermostat - set at just above minimum
    Factory aircon for the Adventure uses rotary dials, by the way.
    Sep 2006
    24 degress here, for my Sentra.
    Aug 2005
    Quote Originally Posted by boknoytm View Post
    Iyong thermostat kasi ay setting kung gaano kalamig sa loob ng car. Mas malamig means na mas madalas naka on ang compressor. Compressor on = fuel consuption.
    Pag tangahaling tapat at nabilad nag car, pag on ng aircon at sinagad, matatagalan bago mag stop ang compressor. equates to lower FC.
    Iyong fan consumes electricity being generated by the alternator, the alternator is powered bg the engine - FC pa rin. Pero mas mahina ang contribution ng pagbaba ng FC ang fan kaysa sa alternator.
    So for me, better na malakas ang fan, pero mababa lang ang setting ng thermostat.
    May mga gumagawa ng baliktad, almost sagad ang thermostat pero naka 1 lang nag fan. pag patay sindi daw ang compressor, mas madaling masira ito. Mahal pa naman daw ng compressor.
    May 2008
    thanks for the tip sir....
    Sep 2005
    Climate Controller ... set at 16° C.
    Jul 2006
    Tiny correction: I think you mean masmataas ang FC (fuel consumption)...
    My car's temperature wheel indicates 18C as cold setting, 22C as in between, and 26C has warm setting. When I drive it depends on the ambient temps, malamig na ngayon sa California kaya middle setting ako usually with minimal blower speed. Tipid rin kasi walang compressor use.
    hehehe. malamig nga.... pero pawisin ako eh. hehehe. the least i had it set is at 11-12 o'clock.
    Aug 2005
    Sorry, baliktad nga pala. pag tumataas ang number ng FC (Km per liter) tumitipid pag bumababa ang number, nagiging magastos.
    Mataas na consumo => Low number na FC
    Mahina na consumo => High number na FC
    Aug 2008
    For me, rule of thumb is: unnecessary use of aircon equals waste of fuel. A 25deg setting means the aircon works less often than the 18deg setting. Note also, everytime the aircon compressor works means more load on the engine, which means reduction on the life effeciency of your engine. Think about it. Choice is yours.
    Wag na lng mag aircon, longer life for the engine.
    But seriously, the more load for the engine, the lesser the FC. Yun lng...not life efficiency.
    Mine's set at 22C
    Dec 2007
    Para sa akin naman, dahil FC means "Fuel CONSUMPTION", tama lang na mataas ang konsumo pag HIGH number ang FC. CONSUMPTION of fuel means how many liters per 100km (or per km, if you want).
    You might have been referring to FUEL EFFICIENCY (km/liter or MPG), like in this webpage: http://www.wikihow.com/Calculate-Your-Car%27s-Fuel-Efficiency-(MPG)
    Nasa 40% ang thermostat dial ko most of the time. Kung sobrang init, 50%. Di ko lang sure kung ano talaga ang temp. setting nun. Hehe.
    Dec 2008
    I set mine at 28 C and sometimes 26 C during very hot days. ginawin ako eh.
What's your aircon temperature setting?
