Results 1 to 6 of 6
March 29th, 2008 03:30 PM #1
Anyone experienced this?
Kapag traffic or low speed Ok ang lamig ng aircon. kapag umandar na kotse ng mga more than 60kph, biglang iinit. pag huminto na naman ang kotse, madidinig mo gagana na yung compressor and lalamig na ulit. Ok naman freon levels, bagong linis din condenser, evaporator, fans, and malakas naman yung condenser fan. hindi ko naman madinig kung nag-sli-slide yung clutch hub kasi tumatakbo sasakyan. 96 civic ang kotse. Parang baligtad di ba? but it actually happenned kangina lang habang kainitan ng araw sa edsa. any inputs?
- Jan 2008
- 380
April 1st, 2008 03:40 PM #2Idiot's guesses lang po:
1. Defective electronic control - Pag Wide Open Throttle (WOT) like when you are accelerating, the ECU will disengage the aircon compressor clutch temporarily.
2. Defective High Pressure cut-off swith ng aircon system- cut din kasi nito current sa aircon compressor clutch pag sobra pressure sa aircon system.
3. Di kaya overcharged ang refrigerant mo - wild and idiot's guess lang.
April 1st, 2008 04:25 PM #3
assuming ecu is okay when WOT, you may consider also the grounding of engine where the comp is attached, it might loosen during at high rpm. it happend to me. Better check, baka poor ang grounding ng engine
April 2nd, 2008 10:48 AM #4
Mukhang unburnished clutch hub/pulley ang problema. mukhang nagsli-slide nga siya during high speed hindi ko lang naririnig. I tried burnishing by turning the AC on and off every 4 seconds about 50 times. na solve ang problema hehehe. thanks for the input guys. sobrang weird ng lang ng experience na to
- Jan 2008
- 380
April 3rd, 2008 08:52 AM #5Maalala ko, sabi nga pala ng tekno sa casa, usually ang mga problemang ganito are more on the the "connection, mechanical, or actuator' side ng computerized vehicles. Yung Computer daw ng car is build to last, meron itong back-up computer para kahit paano ay tatakbo pa rin ito kahit may major problem yung main computer.
Meron din itong RAM to adjust with the changing conditions while you are driving.
April 3rd, 2008 06:09 PM #6
nangyari sakin yan pero baliktad pag umaandar doon nag gagana ang compressor tapos pag stop tigil tapos rining mo na hirap siya mag start ang compressor nakita problem ko is aux fan kasi pag andar may hangin na pasok kaya ikot siya pag tigil wala na. Madali lang ayusin yan baka connection lang
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
