Results 1 to 10 of 20
- Nov 2007
- 2
November 14th, 2007 09:08 PM #1Hello po. Magtatanong lang sana ko tungkol sa kakaibang overheating problem ng Toyota tamaraw fx ko (98 model, 1.8L 7K engine)
Naranasan ko sya lately, nagooverheat sya kapag sinubukan kong palagpasin ng 95KPH ang speed ng fx ko. Tapos hindi siya nagooverheat kapag normal city driving.
Ang nakakaasar pa dito, dati napapaabot ko itong FX ko ng 110KPH ng walang overheating problems.
Any ideas po ba?
Salamat po ng husto...
November 14th, 2007 11:05 PM #2
Check the following:
Oil and water level and rate of consumption.
Leaks on passages and galleries.
Oil and water pump.
Cylinder gasket condition if visible.
November 15th, 2007 12:11 AM #4
Nung nangyari sa MB100 iyan, sira pala yung radiator cap and mabagal ang ikot ng engine fan. Bumili ako ng new cap (Php150.00) and pina-check yung fan.
Start from the basic (and less expensive) stuff first.
BANNED BANNED BANNED
- 3,790
November 15th, 2007 07:00 AM #5ganyan din ang sintomas ng baradong radiator (you need to have it overhauled), non functioning auxiliar fan (possible wiring or motor ng aux fan problem) and yung malapit ng masira na water pump (some of the fins are probably broken na due to corrosion).
November 15th, 2007 07:15 AM #6
pa overhaul mo radiator mo!!! otherwise the best na yung palitan mo ng bagong radiator kung luma na yan mas matipid pa kasi ang kinalabasan kung papalitan mo na lang ng bago ang radiator kaysa ipahinang pagmay leak.
then pa check mo rin cooling fan
also check water pump baka gastado na.
pero higit sa lahat tingnan mo oil/oil level mo kung mabilis ang bawas o di kaya may halong tubig(chocolate kulay)nyan, eh handa ka na sa malaking gastusin sa pag pa overhaul(top overhaul) sa engine.Last edited by dbuzz; November 15th, 2007 at 07:18 AM.
November 15th, 2007 07:26 AM #7
Check mo yun cylinder head gasket kasi kung pagpatakbo mo siya ng 95kph tsaka siya nag overheat defenitely sobra lakas na ikot ng fan nyan.dahil yun fan nya nakakabit sa makina. kung palitan mo yun radiator mo cguro mas maganda kung pang c-190 na yun kabit mo 4 rows sya....
November 15th, 2007 07:34 AM #8
clogged radiator lang siguro yan.. nagyari na rin sakin yan.. nag ooverheat pero may tubig naman ang radiator hehehe
November 15th, 2007 08:37 AM #9
Naranasan ko before naman, is that nakalimutan ng mekanikong ibalik ang radiator cap. I didnt bother checking na kasi, sabi nya ok na raw. Nagulat na lang ako umuusok na ang harapan ng kotse ko, di naman tumataas ang water temp gauge. Hehehe. Seriously, check mo radiator cap muna then reservoir, etc. .
- Nov 2007
- 2
November 15th, 2007 10:20 AM #10Checked the following:
Oil level: normal at kaooil change lang po last month
water level: normal, kapapalit lang po ng radiator cap 3 months ago
hindi po makita condition ng gasket.
Will try na ipaoverhaul yung radiator. baka po kasi nag"semento" dahil deep well po ang ginagamit kong tubig.
salamat po sa tulong...
In that case, I think NCAP is something that they have privatized.
SC (temporarily) stops NCAP
