Results 1 to 4 of 4
Tsikot Member Rank 4
- Jan 2003
- 2,979
April 4th, 2012 02:12 PM #1ok naman yun lamig kapag umaandar or kapag ni-rev mo yun makina. kapag idle lang talaga saka mababa yun rpm niya kapag nag switch on na yun thermostat ng aircon.
ride is mitsu pajero. Related ba sa throttle at kickdown cable yun rev ng compressor? inadjust ko kasi yun kickdown saka throttle cable since may sag yun cable saka sabi na rin nung aircon tech na parang mataas yun rpm ng makina.
April 4th, 2012 10:05 PM #2
April 6th, 2012 02:57 PM #3
pag okey ang charge ng refrigerant and nalamig pag naka rev, ang engine mahina na ang discharge pressure ng compressor, 10k lang compressor ng pajero, additional materials ang service fee...
April 6th, 2012 04:00 PM #4
Dun sa toyota ko, mahina na daw compression ng compressor. Suggestion ng shop ay change compressor na. Makes a pretty bad sound din when you listen closely. D lang gano halata kasi maingay yun diesel. Hindi ko pa napa estimate.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
