Results 1 to 9 of 9
- Aug 2006
- 11
September 19th, 2006 04:03 PM #1Hi guys! Just went to one of those japan surplus shops. And i saw the JDM version for my corolla 97 model where aircon control panels are push buttons. I know i need to change my control panel to accomodate the switches from manual to push buttons. But can anyone give me more idea as to what are the needed task to be done if i pursue this project. Will it require more things to be done? Will it entail total change in terms of re-wiring or more parts? I would appreciate any advise....thanks
September 19th, 2006 05:26 PM #2
Are you talking automatic climate control or just a regular aircon? If it's a regular aircon, it might not be much of a chore, if it's an automatic climate control unit, the wiring may be very difficult.
- Aug 2006
- 11
September 19th, 2006 06:10 PM #3Yes sir its just the aircon... but do i need additional parts to convert the manual switch to push button which i think is electronically triggered?
BANNED BANNED BANNED
- 3,790
September 19th, 2006 10:07 PM #4yung on-off lang ng a/c is easy....but if you're pertaining to the thermostat from analog to digital...you'll need to get the thermostat sensor ng digital and the "brains" ng digital control.
yung analog works like a resitor (knob working on resistance and the sensor probe is producing conductance) na temperature sensitive. Yung digital, kinukombert pa yung conductance to digital factor by a "brain" unit and then relayed dun sa read-out (like saying it is 18 dec C ...etc).
September 19th, 2006 10:11 PM #5
Yung vent selector din ng manual is via bicycle cables. Kapag automatic, via small motors ata siya.
Kung maayos pa naman ang stock system mo, I don't really think it's worth the risk.
- Aug 2006
- 11
September 20th, 2006 01:28 PM #6Thank you very po for all your advices...I will put everything into consideration. I just thought to put something new/project for my car. Will check if i could make it possible otherwise will put it on hold.
September 20th, 2006 09:18 PM #8
may sariling servo din ang automatic climate control iirc. at least for mitsus.
btw, i renamed your thread and moved it to the workshop section.Last edited by ssaloon; September 20th, 2006 at 09:20 PM.
- Aug 2006
- 11
September 22nd, 2006 07:14 PM #9Sir SSaloon,
My thread is regarding conversion from manual A/C to push button controls only. Not Auto climate control. I thought ive cleared that already from your previous question. Anyway, thank you again for your advices.
If that's the case, then it isn't cheap. More like a headache down the road, kahit pang coding...
2021 Nissan Leaf
