Results 11 to 20 of 30
December 10th, 2007 10:39 AM #11
mas mabilis mag evaporate at natatapon ang tubig pag walang radiator cap. Delikado sa overheat.
May mga old cars na tumataas ang temp pag di puno ang radiator.
December 10th, 2007 12:09 PM #12
The adverse effects of running without your radiator cap, you've already experienced.
The cooling system is designed to run under pressure.
This is the reason why you should not fill the coolant reservoir completely since once the mixture heats and expands in your system, the excess will go to the reservoir and once things cool a bit, it sucks the excess back into the system.
This will not work effectively if there is no pressure.
Replace your missing cap as soon as possible and be careful to avoid the same situation in the future.
Hope this helps.
December 10th, 2007 12:28 PM #13
ibili mo na ng cap baka may masira pa sa tsikot mo, P90 lang yung silicon-type na radiator cap sa auto supply.
Tsikot Member Rank 4
- Jun 2006
- 2,605
December 10th, 2007 03:47 PM #14Buy a new radiator cap. Mura lang yan. Kung walang cap, ubos ang tubig at overheat ang resulta.
Radiator caps also acts as a pressure relife valve. It also increases your coolants boiling point to around 126 Celcius. Here is the explanation:
http://auto.howstuffworks.com/cooling-system7.htm
- Dec 2007
- 5
December 10th, 2007 07:05 PM #15wow thanks sa inyo guys overwhelmed naman ako sa mga replies.. anyways nakabili na ako ng rad cap and observe ko muna kung ok naman yung sasakyan hopefully wala naman maging problema.. thanks ulit!!! more power to tsikot!!!
nurse on wheels
- Dec 2006
- 392
December 10th, 2007 11:46 PM #17if you're looking to replace your old oem caps, i highly recommend federal mogul. im using them on our 3 vehicles. hth
Tsikot Member Rank 5
- Nov 2003
- 3,848
December 13th, 2007 12:06 PM #19
theory: kung bakit kailangan pressure tight ang engine cooling system (that includes the rad cap). plain water and at atmospheric pressure will boil sa 100 deg C, raising the pressure will raise the boiling point (boyle's law ba un or charle's law he he forgot ko na). kaya kailangan pressurize ang system and adding coolant will also raise the boiling point.
- Oct 2007
- 1
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
