Results 1 to 10 of 30
- Dec 2007
- 5
December 9th, 2007 10:06 PM #1good evening tsikoteers newbie lang po ako and ask ko lang kung may masamang effect ba itong pagtakbo ng walang rad caps? kasi itinakbo ng bro ko yung car namin kagabe mula binan to cavite and nung magpakarga sya sa petron pinacheck nya yung tubig pero sad to say hindi ata naibalik ng gas boy yun radiator cap and hindi din alam ng bro ko na ganun.. nakauwi naman sya ng walang problema pero ngayon lang inilabas nya uli yung oto to sta.rosa laguna then nun pabalik na sila nanotice nila na biglang tumaas ng sobra yun temp so chineck nila agad and ayun wala na nga yung rad cap.. idinaan nila sa isang gasoline station and sabe naman na maiiuwi pa yung oto kaya lang dapat mabagal lang takbo.. ngayon medyo worried lang ako na baka may masamang epekto itong ngyareng ito.. bukas ako bibili ng rad cap para magamet na ulit? so ok lang po ba yun wala po bang masamang epekto yun balik to norman ba pag nakabili na ako ng rad caps? thanks in advance po and more power to tsikot!!!
- May 2005
- 208
December 9th, 2007 11:42 PM #2nangyari na sakin ito. buti hindi nahulog yung rad cap habang tumatakbo ako. buti kabibili ko lang ng wilkins.
effects:baka masira block?
December 10th, 2007 08:40 AM #3
I guess meron effect, pa check mo na lang to be sure...sobrang naubusan na ng tubig yan, kung yun defective nga na radiator cap eh sobrang nagbabawas na ang tubig yun wala pa kaya...hehehe
wait mo na lang mga expert dito kung ano dapat pa check
- Jan 2007
- 409
December 10th, 2007 08:43 AM #4ok lang yon - the cooling system of your car/vehicle won't be efficient - puwede yan no aircon and don't race your engine (hi rpm). Kung walang traffic and gabi naman no problem yan. PLUS if he was watching his temp gauge na hindi magredline ok lang.
DIY to death!
- Jan 2003
- 451
December 10th, 2007 09:10 AM #5When you said, "biglang tumaas sobra yung temp," how high was it exactly? Did it boil over? Kung hindi naman, then you should be fine. No caps or even defective ones lowers your cooling system's efficiency very drastically, as what you've just experienced. But if you didn't overheat, then just buy a new cap and rest easy. ;)
December 10th, 2007 09:30 AM #6
normal lang iyun pag taas ng temperature dahil natatapon iyun tubig sa radiator... kailangan makuha muli radiator cap sa pinagkargahan or bumili ka ulit ng bago... hirap na baka maubosan ng tubig ang radiator at bigla kakatok ang makina. gastos sa overhaul.
December 10th, 2007 09:36 AM #7
I had this bad experience before sa previous mekaniko ko. When I had him do something with the car, and I picked it up after office hours, I immediately drove the car pauwi. Na notice ko na lang when I was already halfway home (around 20 kms na tinakbo), umuusok na ang harapan ng sasakyan ko, but when I checked the temp gauge at midpoint naman. I immediately parked the car, and opened the hood, lo and behold the radiator cap was not properly put on. Naubosan na pala ako ng tubig. What I did was that I placed water (mdyo nagiispill nga e). I don't know if it was the right thing to do during that time, pero nagpapanic na ako coz medyo madilim na na lugar yun and walang masyadong katao tao. Sa awa ng diyos nakauwi pa naman ako. The following day I talked to the stupid mechanic, and he admitted it. Sad for him he lost a customer because of what he did.
Pero one thing I notice lang is that jeepney drivers here do not place a radiator cap sa mga sasakyan nila. They just refill water from time to time.
December 10th, 2007 09:53 AM #8
let the car cool down first before adding water otherwise magkaroon ng thermal shock iyun engine at possible mag crack ang engine block...
mga jeepney wala nga sila radiator cap, pero masdan niyo everytime nag stop sila ng matagal karga karga sila ng tubig...
December 10th, 2007 10:07 AM #9
Iba naman sir ang radiators ng mga jeep at masyadong mga oversize yan unlike sa mga kotse na sobrang liit.
Pero as long tumatakbo yan ng maayos at di naman nag overheat after mo lagyan ng tubig ay ok lang yan. Sisirit kase ang tubig nyan pag walang takip .. ang nakakatakot lang kung minsan ay madami talagang bad effects ang overheating and worst is tamaan talaga ang engine pero depende naman talaga yan.
but it I think your case should be alright since umaandar naman kotse mo, obserbahan mo na lang.
December 10th, 2007 10:20 AM #10
Thread was made nung 2018 pa po sir.
