Results 1 to 10 of 89
December 5th, 2019 10:30 AM #1
- 54,283
December 5th, 2019 10:50 AM #2
December 5th, 2019 11:11 AM #3
We used to do that in all our Taxis (after the radiator was replaced by a "replacement")
Using a Non-factory spec radiator (normally made of copper) has only 2 pros, it's easier to repair AND during those hot summer days, spraying the radiator with water can help the A/C.
But based on experience with replacement radiators.
It's bigger - but the rows are actually smaller
It gets hotter, higher chances of the hood fading quicker
I would also recommend to remove the thermostat as I'm not sure how will local radiators hold up.
Only issues I noticed with removing the thermostat is that (1) it will take longer for the car to warm up, if you're driving short distances, it can be really annoying.
(2) when driving at high speeds out of town, the engine temp will be lower than usual, hence again not reaching the optimum temp of the engine.
- 54,283
- 54,283
December 5th, 2019 11:20 AM #5the aluminum-versus-copper-radiators arguments are in the innernet.
na-hilo ako.
having experienced "financial diversity" in life, i appreciate the copper-being-repair-able part. aluminum radiators can be repaired, but it takes special training and special materiel.
someone advised me, "when the radiator starts leaking, replace it. even if you are able to repair that leak, others will follow soon."
so, what was the reason daw, that made removing the thermostat a good move?Last edited by dr. d; December 5th, 2019 at 11:23 AM.
December 5th, 2019 11:24 AM #6
- 54,283
December 5th, 2019 11:26 AM #7
December 5th, 2019 11:31 AM #8
yup... our taxis used to run 400kms per day...
but back to the thread...
the car (Gen 2 CRV) is more than 10 years old... how long do you plan to keep it?
forever - buy a replacement but you may need to make adjustments here and there. also there's chances of mali yung mabili mo. then bibili ka ulit nang bigger then adjustment ulit.
upto 5 years - buy original, baka baratin ka ng buyer if mapansin nya na replacement yung radiator mo tapos modified bracket ng fan - happened to our Adventure
- Feb 2017
- 28
December 5th, 2019 09:53 PM #9
Maybe 3 years or even more.
was hoping may nakapagtry na dito with their crvs using 2 rows, dapat nga siguro 1 row nalang since yun nga ata ang stock.
looking now for evercool like the one posted online laz, since dami good review but a friend told me good daw ang made in thailand.
December 5th, 2019 12:18 PM #10
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
