Results 1 to 10 of 22
- Sep 2016
- 72
November 21st, 2016 01:02 PM #1this is the story. Kapag pinaandar ko ung makina e ok naman ung level ng coolant sa radiator.pero pag pinatay ko na e nababawasan ng 1 inch level na coolant but when i start the engine again, the coolant level rises again. Is that normal?
- Oct 2009
- 2,271
November 21st, 2016 01:11 PM #2sa radiator ba mismo nababawasan or sa reservor.pero kung pag lamig nang makina ay balik sa dating level eh normal lang yan.
- Sep 2016
- 72
November 21st, 2016 01:57 PM #3sa radiator sir. inobserve ko.finill ko ng coolant ung radiator then i started the engine without putting back the radiator cap in order to observe the coolant level.after that i turned off the engine and the coolant level is slowly decreasing up to 1 inch in just 5 mins like that.
- Jun 2005
- 3,774
November 21st, 2016 02:00 PM #4Parang normal lang naman.
Gumagana water pump kaya hindi settled ang tubig.
- Oct 2009
- 2,271
November 21st, 2016 02:07 PM #5normal lang yan or kulang pa sa bleed ung cooling system mo.
gamitin mo maghapon,tapos kinabukasan ng umaga mo i check kung nagbawas sa radiator at sa reservor.
kung nag bawas.lagyan mo ulit.saka mo gamitin ulit.tapos kinabukasan ng umaga wag mo muna paandarin i check mo muna ulit kung nabawasan ung rad at reservor.kung nag bawas.ibig sabihin may leak.pero kung hindi naman normal lang yan..
- Sep 2016
- 72
November 21st, 2016 04:23 PM #6kkapag po papalitan ko ung radiator ko.anong type ang magandang ipalit? sabi nila mga radiator ngayon e hindi kasing tibay ng rad noon.
November 21st, 2016 04:41 PM #7
may thermostat ba o wala yung makina?
hindi sigurado kung meron o wala? para malaman e ganito:
kelangan malamig ang makina. tapos tanggalin ang cap at paandarin ang makina. kung nagcirculate agad ang coolant e tinanggal ang thermostat nito. palagyan mo kung wala nga. mura lang naman. wala pa isang libong piso.
kahit na palitan mo radiator ng mas malaki kung walang thermostat e ganyan pa rin ang ugali nyan.
- Oct 2009
- 2,271
- Sep 2016
- 72
November 21st, 2016 05:52 PM #9L300 mitsubishi sir. dami kong pinapalitan dito.hahaha.nakabili na sana ako ng underbone na motor.hahaha
- Sep 2016
- 72
November 21st, 2016 05:53 PM #10
soy-based wire insulation. 1. cheaper than the petroleum-based plastic insulation. 2....
BYD Philippines
