dagdag ko na rin, pwede din talaga na mainit yung radiator mo kaya nakabukas sya although engine is off. pero once na you have the ignition switch to off position or the key removed, the fan shoudn't be running anymore. my auxiliary fan was till running when key was removed, so i didn't need to observe if it would turn off after a few minutes. in my case the relay was the problem
